Mpp
Mpp
Old 1st November 2012, 08:13 PM   #7621
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
....but I don't think that we will see this available for us any time soon!
Old 4th November 2012, 06:53 PM   #7622
schwalbe is offline schwalbe  Germany
Can anyone help me with a parts list and is a builders manual available?
Old 4th November 2012, 07:42 PM   #7623
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Look here Paradise phono stage
RC
Old 5th November 2012, 11:03 AM   #7624
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
@Schwalbe,
soon a german version of building guide will be available.
preregulatorpeterE-MAIL
Old 6th November 2012, 04:44 PM   #7625
nhinstruments
RCruz's Avatar
Mpp
Hi
Can I use only one TX to feed two prereg psuīs to power the Paradise ?
I have one suitable TX that has double output windings and would like to minimize crosstalk using double bridges and caps, forming two psuīs.
I am afraid this might cause hum due to using the same TX secondaries to feed both bridges in parallel.
Can it be done like this ?
RC
Old 6th November 2012, 04:45 PM   #7626
Originally Posted by Benedetto View Post
@Schwalbe,
That's fine, thank you for the information.
Old 6th November 2012, 05:27 PM   #7627
pdul is offline pdul  Denmark
Hi
Cant see any problem with that, you should pay attention to the groundwiring though when you implement it.
After all, you use the same powergrid anyway, for your mains
Old 6th November 2012, 05:45 PM   #7628
FdW is offline FdW  Netherlands
FdW's Avatar
Mpp
Originally Posted by RCruz View Post
Hi
Yes you can, but you start off with a ground loop inherently build in and that may get to be a problem. I would advise to use 2 TX's to prevent this. If you select to use one TX then you need to take good care of the grounding scheme that you are going to use.
Old 6th November 2012, 07:48 PM   #7629
nhinstruments
RCruz's Avatar
Mpp
Hi Frans
That is my main concern... I once used a similar configuration and got a hum issue I could not solve.
Would you please point me the ground loop ?
What do you suggest as a good groundin scheme to avoid itīs intrusiveness ?
RC
Old 6th November 2012, 08:23 PM   #7630
FdW's Avatar
Mpp
Hi Frans
The 'ground loop' is more like a multiple connected ground system, where one connection is routed though the transformer (both amps share the same ground return to the TX) and the other connection is at the input (the shared return/ground of the cartridge/player). The shared cartridge connection can be broken by using a 5 wire connection to the player (connecting Left+ and Left- to the left amp, Right+ and Right- to the right amp, and having a separate player ground to the amp ground).
This is not something that I have experience with, and something that I would not advice. My advice is, get 2 TX's
MppHide this!Advertise here!
