Mpp - Page 760 - diyAudio
Old 14th October 2012, 03:36 PM   #7591
Joachim Gerhard's Avatar
I have some autistic tendencies.
Old 14th October 2012, 04:42 PM   #7592
pdul is offline pdul  Denmark
Old 14th October 2012, 11:30 PM   #7593
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
I have some Suicidal Tendencies.
Paradise Pre-reg PSU PCBs
Old 14th October 2012, 11:41 PM   #7594
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
What surprises me is that you do not have murderous tendencies!
Old 14th October 2012, 11:52 PM   #7595
That surprises me too but i feel piece full inside.
Old 15th October 2012, 03:51 AM   #7596
Stefanoo's Avatar
Originally Posted by RCruz View Post
The values I got from simulating helped by my riaa calculator (spreadsheet).
There are variables that I am not totally sure about and that I believe can be different from build to build... Namely first stage output impedance and buffer input impedance.
So it is difficult to predict "exact values", but mine are very near yours.
I always measure the components and do adjustments to reach a "probable" precision.
I mainly use a listening panel to evaluate the results and compare with other builds.
Anyway, based on the reports from other builders that used "stock" riaa and caps values, it sounds very good also so I believe it might be system dependent.
Regarding the EL caps, after discussing the subject with JG, I used lower values because I did not have the indicated values, so I do not have the means to compare... but in my case it works wonderfully.... Paradise bass is outstanding IMO.
I am really glad this turned out to be a very flexible design that responds well to tuning.... We will learn a lot from the numerous builders subjective input to come soon
so the graph was from simulation.
Anyhow, like I said the bass with a lower elcap won't loose any grip as you are experiencing, but, the mid and high will be much more transparent.
I am glad you like it so far.
Also, the precision I gave along with the values I suggested is actually extracted by bench measurements.
Therefore using the values I quoted will yeald to a very, very tight precision and I am glad because this matches really close simulation.
Yes, design respondes pretty well to tweaking like I anticipated.
The biggest improvement will come from the custom teflon caps for the RIAA but it's too early to talk about this.
enjoy your build and thanks Joachim for this slick design.
Stefano
Old 18th October 2012, 09:44 PM   #7597
Algar_emi's Avatar
Hi. I think there may be an error in the Regulator R3 schematic. See the included schematics. In the R3 version schematic the +Side of C103/C203 is connected to the VPLUS/VMINUS line on top (circled in red). In the previous R1 and R2 version of the schematic, the same capacitor is connected to R105/R205 to act as a filter for the led bank voltage reference. It think this is the correct way of connecting C103/C203 but I may be wrong.
Which schematic is the correct one?
Old 18th October 2012, 10:11 PM   #7598
Hesener has the official schematic so he should commend here.
Old 19th October 2012, 10:33 AM   #7599
hesener is offline hesener  Germany
Thanks for spotting this, I reviewed the versions and we decided to change this connection to VPLUS/VMINUS in version 2. So version 2 and also version 3 have the caps connected there, only version 1 had it connected at the resistor / LED junction.
Everything OK.....
Old 19th October 2012, 08:30 PM   #7600
Algar_emi's Avatar
Thanks. But my PCB is wrong then I'll do a quick mods
Copyright 1999-2017 diyAudio
