MPP
MPP
Old 13th October 2012, 03:44 PM   #7571
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Me too, this is extreme. The lowest cartridge i know is the Audio Note IO with something like 0.1mV.
Old 13th October 2012, 03:47 PM   #7572
I was wrong, the IO Ltd. has even less :Audio Note
Old 13th October 2012, 03:50 PM   #7573
Or this one :Audio Note
Old 13th October 2012, 04:11 PM   #7574
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
The Ortofon SL15 MKII ... 0.015mV
RC
Old 13th October 2012, 04:32 PM   #7575
mkoerner is offline mkoerner  Germany
Ahem, the value in the datasheet was given at 1cm/s. At the more common 5cm/s it looks more reasonable, thank good: 0,35mv at 5cm/s!
Well as there aren't that much low Output MMs I'm surprised Holger didn't realise. It's a Pickering XLZ-7500S.
Mike
Old 13th October 2012, 04:44 PM   #7576
That should work.
Old 13th October 2012, 04:49 PM   #7577
Thanks. Then I'll first do the Paradise
Mike
Old 13th October 2012, 04:49 PM   #7578
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
You shouldn't be .
I am not that deep into vintage cartridges.
Best regards: Holger
www.holgerbarske.com
Old 13th October 2012, 05:01 PM   #7579
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
MPP
This is my PCB almost all assembled. The Pre-Reg is working fine, just waiting for the last part order to get the remaining transformers. The preamp PCB are only missing the 337/327 matched transistors. I'll make the RC filter small PCB today while continuing to measure the transistors HFE.
Old 13th October 2012, 05:13 PM   #7580
Algar, that looks pretty awesome. good work. I hope it will play without much trouble shooting. Have fun !
MPPHide this!Advertise here!
