Mpp
Mpp
Old 11th October 2012, 03:16 PM   #7531
pdul is offline pdul  Denmark
I am going to divide my cabinet into two sections, one for transformers/powersupply, and one for the rest of the preamp. Which material is the better one to make the shielding between the two sections, copper or aluminum?
Old 11th October 2012, 03:22 PM   #7532
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Mpp
Copper.
Old 11th October 2012, 04:02 PM   #7533
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
We made PCBs for the preamp and the power buffer. It did not catch on much.
I have to search for the schematics.
File Type: jpg Power Buffer and High Speed Pramp PCB.jpg (407.3 KB, 259 views)
Old 11th October 2012, 04:04 PM   #7534
Bksabath is offline Bksabath  United Kingdom
Banned
Copper as well but why not 2 separate enclosures?
Got same Stainless Steel (non magnetic) in My Paradise tread.
I will use copper lining on the Phono as well.
Mu Metal is out of my price range at present, still Paradise work realy well witout to much fussing about...
Old 11th October 2012, 04:20 PM   #7535
HTML Code:
I already have a nice and expensive cabinet from Italy, which i bought some time ago, for a preamp project, and the paradise came as sent from heaven since the phono section, was the only link missing, to make it complete. I have the linestages, the input selector, and a relay volumecontrol. My aim is to make a good preamp in one box
The pics is from when i tested the line pcbs.
Old 11th October 2012, 04:26 PM   #7536
Nice preamp circuit. I like it.
Old 11th October 2012, 04:32 PM   #7537
It works well too
Old 11th October 2012, 05:17 PM   #7538
Who designed it ?
Old 11th October 2012, 05:27 PM   #7539
Some new information :
In an open loop phono like the Paradise it can happen that the channels have a slight mismatch in gain, say 1dB. That can be corrected by using slightly lower value emitter resistors on the softer channel.
Old 11th October 2012, 06:12 PM   #7540
Who designed it ?
Originally Lars Clausen. It was part of a Danish diy project in The High Fidelity magazine back in 91-92. Later i took it out of the preamp project and altered the components into something available, and Dimitri tuned it a little and made a nice pcb layout
Pictures of the original project and Dimitris pcb layout.
MppHide this!Advertise here!
