Mpp
Mpp
Old 7th October 2012, 04:04 PM   #7521
Bksabath is offline Bksabath  United Kingdom
Banned
Tanks Joachim
I shuld have put this better, I do not imply design flaw, if this is not clear you and any naive reader have my apologies.
Just jumping the gun realy as I am thinking about next build with 1% resistors and limited suply of Jfets.
Old 7th October 2012, 04:41 PM   #7522
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Did you build with resistors that do not have 1% tolerance !
Old 8th October 2012, 09:38 AM   #7523
hesener is offline hesener  Germany
Mpp
Originally Posted by Algar_emi View Post
Hi. Since the official R3 PCB was no longer available, I did my own
I also did a pcb for the pre-reg according to the included schematic. I should have them built by the end of the day.
The latest version of the parts list match these PCB.
Very cool!! I like it. Sorry you couldnt participate in the group buy.... In fact, we have 3-4 people on the waiting list so that may eventually lead to another group buy, unless you would like to do one with yours?
Old 8th October 2012, 07:38 PM   #7524
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Mpp
I assembled and tested the Pre-Reg PCB. There was an error that is now corrected. Output voltage is around 31V at 120ma supply current. I find it a little on the high side for the preamp shunt reg (35Vmax to 25Vmin recommended). In order to lower the heat dissipation of the shunt reg, I did a simple RC PCB (forming a CRC filter with the caps on the preamp). It is intended to be installed between both preamp pcb. It will lower the pre-reg supply to about 28V, adding some more filtering in the process. I did it using parts I had in stock, nothing fancy. I modified to BOM to add these parts.
Old 8th October 2012, 08:53 PM   #7525
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Hi Algar
Do you use 0.1uF caps to bypass the rectifier diodes or did you plan snubbers ?
RC
Old 9th October 2012, 04:20 PM   #7526
The Hammond transformers are now coming in from Digikey.
i have now all parts to build a Paradise pre regulator.
Old 10th October 2012, 04:51 AM   #7527
uli67 is offline uli67  Germany
Hello Joachim,
i'm looking forward, to your preregulator and I hope it will come soon.
Today evenig we had a listening session by Andrejs with your
proto-paradise V2
.... very impressive....
especially with his great BB-OB setup and other specialities.
i´m so happy that I appointed three sets
Greatings from Münster
Old 10th October 2012, 01:54 PM   #7528
Thanks Uli, Andrejs also told me that he gets very good results.
Old 10th October 2012, 08:01 PM   #7529
dcd3500rg is offline dcd3500rg  Germany
Hi Joachim
is there a line amp and a power amp(DIY) that fits to the qualities of the Paradise phono amp?
Roland
Old 10th October 2012, 08:15 PM   #7530
I have posted that before. The Rose and a fitting power buffer. Have to find it though.
MppHide this!Advertise here!
