| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#7481 |
Alfred, i have read your instructions. I like it a lot.
I will read the offset part again and may do some additions i talked about. Also on the matching of the input devices. |
#7482 |
The buffer off set can be adjusted with the resistor. with the SK170 and 5 ohm it is app 60-70 mV.. with 11 ohms it practically Nill... (8,5 mA through the Jfet)
#7483 | |
RC |
#7484 |
Hi. Since the official R3 PCB was no longer available, I did my own
![]() I also did a pcb for the pre-reg according to the included schematic. I should have them built by the end of the day. The latest version of the parts list match these PCB. Last edited by Algar_emi; 5th October 2012 at 09:40 PM. |
#7485 |
Question about the BC327/337 HFE matching. Is it necessary to match all the transistor one one channel pcb, or just the Gain Cell ones (Q2,25,26,29 and Q1,30,31,32). And finally, I guest it is necessary to match both channel together as well to get the same gain?
Thanks. |
#7486 |
yep the input devices.
also it would be good to match the current mirror (not the one on the servo) for best performance.
Stefano |
#7487 | |
Paradise Builders Se post 13 Match 10% or better pick closest matched and fit in groups as in circuit Imput Current mirrors and soon |
#7488 |
Cool, we have a PCB for the prereg.
#7489 |
Here the completed PCB. Do we need a GB for the Pre-Reg PCB
#7490 |
Well, i was designing a prereg too that could lead to a group buy. That is obsolete now.
I would like to try your PCB and add chokes and output caps eventually. |
