Mpp
Mpp
Old 23rd September 2012, 04:58 PM   #7401
pdul is offline pdul  Denmark
No contact lenses to extend the vision to reach the glasses.
In short, no preamp.
Old 24th September 2012, 01:59 PM   #7402
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
I am going to post shortly a balance topology I have tried to prototype.
Stefano
Old 24th September 2012, 03:04 PM   #7403
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
As far as i can tell this is a linear stage without RIAA. When you ramp up the gain you get noise, sure. If you would put a transimpedance RIAA after the mirror your noise from 1 kHz and up would drop. If you ramp up the open loop gain to 80dB plus transimpedance RIAA your gain at 20kHz would be 40dB, so 10dB less noise then what you have right now.
The gain of that RIAA would be 60dB nominal. Are the sources of 2SJ74 connected to the cascades and when, why ? There are other measures to lower the noise, that comes later.
Old 24th September 2012, 03:57 PM   #7404
Stefanoo's Avatar
Joachim...
for some reason my post above disappeared....where you commenting at my post?
It's not there anymore....
Stefano
Old 24th September 2012, 04:01 PM   #7405
I do not know why it disappeared. I thought you had erased it to correct an error.
I have downloaded your circuit though and it is pretty cool. Yes, my commend was targeted at this post. Please repost it.
Old 24th September 2012, 04:11 PM   #7406
Stefanoo's Avatar
I am sending you an email...
Stefano
Old 24th September 2012, 06:09 PM   #7407
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Hi Stefanoo
Would you please repost your schematic ?
RC
Old 24th September 2012, 07:02 PM   #7408
Stefanoo's Avatar
After chatting in private with joachim, I decided under his request to repost it.
The disclaimer is this:
I will open up a new thread and the name of it, chosen by our master Joachim is Masterpiece as it is based on the Paradise's technology.
Also, this is not going to be a group by, so the experienced people here will be able to build it on their own.
I will be in charge for building concept prototypes and test solution so that we can easily move forward.
the circuit has to be considered as a starting point as it needs adjustments.
I will post shortly and link here the new thread.
Stefano
Old 24th September 2012, 07:04 PM   #7409
Good solution i think.
Old 24th September 2012, 07:39 PM   #7410
Stefanoo's Avatar
Thanks Joachim...this is going to be a very exciting project.
Link to the new thread:
Masterpiece
Stefano
MppHide this!Advertise here!
Copyright ©1999-2017 diyAudio
