Old 14th September 2012, 02:39 PM   #7331
Joachim Gerhard's Avatar
Wow, that is a much better price then at Mouser. Thanks, Holger.
Old 14th September 2012, 03:28 PM   #7332
pdul is offline pdul  Denmark
I am surprised, that nobody has talked about making the listening room into a Faraday cage to complete the rf filtering
Old 14th September 2012, 03:46 PM   #7333
I have this trafo 230v to 230v 1200va. Will it make any difference to run the mains thru that one, regarding rf.?
Old 14th September 2012, 03:54 PM   #7334
Holger Barske's Avatar
Depends on the transformer.
A normal transformer has reasonable capacitive coupling between primary and secondary windings, which is a pleasant path for high frequencies.
The bigger the transformer, the higher the capacitance, the bigger the problem.
There are transformers with a static shield, which will help with this.
Best regards: Holger
www.holgerbarske.com - Deutschsprachiges Paradise-Support-Forum
Old 14th September 2012, 04:08 PM   #7335
It was not made for hifi, it was used for isolated control voltage in a big crane So its probably not so good except for damping of spikes.
Old 14th September 2012, 04:23 PM   #7336
Maybe one time i will make actual measurements on transformers to find out how wide band different makes are.
i have a little time today .....
Old 14th September 2012, 04:39 PM   #7337
With isolated net, you have zero potential to ground. Is it wrong to asume that it aplies to rf and other polutions in the supply too?
Old 14th September 2012, 05:44 PM   #7338
Yes. It is wrong .
A transformer generally solves the galvanic part of the isolation, but capacitive coupling is another story.
Old 17th September 2012, 06:35 PM   #7339
I have a lot of BC337-40 with Hfe of 400 - 450 with no matching PNP.
When somebody here has too much BC327-40 with Hfe 400 - 450 i would like to buy or trade 200 pc.
I hope this deal is not big enough to put into vendors bazar.
Old 17th September 2012, 07:00 PM   #7340
Same problem here 327 hfe 300-390 and 337 460-590 all Unfairchild.
The Diotec´s has much better/more matches.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
