MPP
MPP
Old 11th September 2012, 04:02 PM   #7321
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Here is a photo of the commercial version of the Suesskind Opus Magnum Pre-Regulator.
The PCBs have special aluminum inlays to cary the heave coils.
I am working on a more economical DIY version for the Paradise.
Old 14th September 2012, 01:03 PM   #7322
I have now found a coil that should be ideal.159Y Hammond Manufacturing | Mouser
It can cary 750mH, has 600mH and 11Ohm.
I choose high current capability so that a single pre regulator can drive a stereo set of Paradise.
Old 14th September 2012, 01:14 PM   #7323
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Or, at the cost of a few volts, this one 158T Hammond Manufacturing | Mouser.
It has higher inductance and a bit of resistance that actually may help to damp it. It is cheaper and lighter, and good for 300mA.
Old 14th September 2012, 01:31 PM   #7324
mad_z is offline mad_z
I am using 159ZJ in similar application as per advise from John Swenson.
Old 14th September 2012, 01:35 PM   #7325
The 158T is not enough for two boards. For double mono it is fine.
I did not tell you before but in praxis the Paradise R3 draws over 200mA per channel despite the attempts that have being made here to calculate the current draw mathematically.
Old 14th September 2012, 01:43 PM   #7326
FdW's Avatar
MPP
That could be '159ZA 300mH 1A 6.0ohm 500 2.50 C14H'. At the cost of mH's these go for low-resistance values, and high currents. This is needed if you do not have 'volts' to spare (so to say) or have a high current need. But if you do a new design, for low currents, you can select a transformer with a few volts more to spare, and use one with more mH's and a higher resistance, both will help make a better filter. I actualy like the higher resistance, for low current small signal circuits.
Old 14th September 2012, 01:45 PM   #7327
FdW's Avatar
MPP
O.k. thus the 158T for dual mono and the 159Y for single supply?
Old 14th September 2012, 01:53 PM   #7328
Yes, i think that is cool.
I will then make dual mono pre regulators with 4 158T and the transformers i have shown.
I will use Mundorf elcaps though. I know they sound good and they are not much more expensive then the F&T. You can use any good elcap that you want though.
Old 14th September 2012, 02:16 PM   #7329
If you want to go economical this Panasonic ones are just fine :Panasonic Kondensatoren Serie TS-HA - hifituning24.de
Old 14th September 2012, 02:38 PM   #7330
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
Best source in Germany: Tube-Town Online-Store - Hammond Drossel 158T ha158t
Best regards: Holger
www.holgerbarske.com
MPPHide this!Advertise here!
