| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#7291 |
Then they must be good. Still have around an LA Audio tube power amp that sounds decent considering that it is 20 years old. I always come back to it for reality check.
#7292 |
Will MJE 15032/33 be ok as the powertransistors in the Paradise?
![]() Would be nice, since i have a good handfull of those in stock. |
#7293 |
When the footprint is the same they will work.
#7294 |
Ok
Thats a very low demand.
#7295 |
#7296 |
Base, Emitter and Collector should come out of the correct pin. I know, this is pathetic but Japanese transistors often have another Pin Out. On Semi uses the European system i think.
#7297 |
They are On Semi, and they are BCE like tip31, so the pinout is ok. It was more the other specs i was unshure of
#7298 |
I have another question. What if the chokes are connected on the primary of the transformers instead of the secondarys. Wont it have the same efect on RF filtering?
#7299 |
I have shown a circuit how to connect the Telamas correctly.
As ripple filters after the bridges they are more or less useless. |
#7300 |
You can find the circuit in post 7192. They belong behind the transformer and before the bridges.
