Mpp - Page 727 - diyAudio
Old 4th September 2012, 07:33 PM   #7261
mibu21 is offline mibu21  Germany
Very good intention! so everyone will be able to start experiments by themselves but even beginners could build the Paradise by guidance of the chief engineer!
Hurrayh!
Michael
Old 4th September 2012, 08:39 PM   #7262
Joachim Gerhard's Avatar
It could start with this transformer. Simply rectified it has too much voltage. We can drop the voltage in resistors or we can use coils. One transformer is enough for both channels but 2 can be used for double mono.Transformateur R-CORE à fixation sur châssis 30VA - 2 x 24V - Transformateurs R-CORE pour châssis
Old 4th September 2012, 08:43 PM   #7263
This rectifier diode is hopelessly over dimensioned but hyperfast and soft recovery.
Other like Fairchild make similar products.http://www.hifituning24.de//downloads/hfa08tb60.pdf
Old 4th September 2012, 08:48 PM   #7264
Here are some coils that can work. I can ask Reinhöfer to make something special.Reihe M65
Old 4th September 2012, 09:01 PM   #7265
Damn, the 4 poles are expensive, the two poles are ok but there are more affordable alternatives.http://www.mundorf.com/deutsch%201.1/kondensatoren2.htm
Old 4th September 2012, 09:04 PM   #7266
These are not bad :Panasonic Kondensatoren Serie TS-HA - hifituning24.de
Old 4th September 2012, 09:05 PM   #7267
Stefanoo's Avatar
These might be very nice on a Power Amp and surely work great on the phono as well.
Stefano
Old 4th September 2012, 09:07 PM   #7268
Holger Barske's Avatar
Why not. My vote goes for CLC with Hammond chokes or, maybe even more economic, with gyrators as choke replacement (good reading - sry, german only: Spannungsregelung mit elektronischer Brummsiebung (komplementär-darlington, LM350, MJE2955, MJE3055)).
Best regards: Holger
www.holgerbarske.com
Old 4th September 2012, 09:30 PM   #7269
I would vote for a passive solution with coils.
Old 4th September 2012, 09:34 PM   #7270
Good alternative ? Seems to me they have quite same specs.
http://www.fairchildsemi.com/ds/RU/RURP860.pdf
Copyright ©1999-2017 diyAudio
