MPP
MPP
Old 4th September 2012, 08:00 AM   #7241
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by studiostevus View Post
Not here ....
Attachment 299524
For this job I would select inductors with a nice big iron core, like these Power inductors - Mouser Using one of these with 2 capacitors should be good enough (more is always better )
Old 4th September 2012, 08:23 AM   #7242
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Originally Posted by pdul View Post
Have anyone here actually tried the paradise with a standard psu setup, bridge and a pair of capacitors, and no chokes at all? Just for reference
Indeed I did
The Paradise shunts are really good and work wonderfully with a bridge followed by one cap.
I am using a Nichicon 15000uF Gold Tune ("Tuned" in Malasia) and even with this low cost setup it sounds wonderfull.
RC
Old 4th September 2012, 08:30 AM   #7243
pdul is offline pdul  Denmark
Perfect. Meaning that it can work well without 200kg of extra iron and copper in the cabinet
Old 4th September 2012, 08:38 AM   #7244
nhinstruments
RCruz's Avatar
MPP
I do believe there is no need to build a very complex prereg for the Paradise... It,s shunt CCS has a very good PSRR allready.
I only use a small resistor between the rectifier bridge and smoothing cap if I need to reduce raw DC voltage a bit... like this: RC Ripple Filter Calculator
In my actual build I chose the correct TX voltage so I do not need any Vdrop... so, no resistor.
Anyway, I also found that if we use a really good smoothing cap (Jensen or Mundorf 4 pole), we should not place anything between this cap and the Paradise so we can benefit from itīs "benefic" sound signature... That,s how I cook
Off course if one really wants to get the most out of this Paradise one can choose to build a heavy filtering prereg with loads of coils and caps, but it costs and it is not so simple to design correctly.
RC
Old 4th September 2012, 08:41 AM   #7245
nhinstruments
RCruz's Avatar
MPP
Off course you can put the prereg inside the cabinet, but it works much better with an external psu.
Something like this:
RC
Old 4th September 2012, 09:00 AM   #7246
I have a very nice Italian cabinet i want to use, so my plan is to build a cabinet within the cabinet for the powersupply
Old 4th September 2012, 09:04 AM   #7247
nhinstruments
RCruz's Avatar
MPP
So you plan to place the TX near the amp boards right ?
RC
Old 4th September 2012, 09:12 AM   #7248
My plan is to build a small cabinet for the powersupply inside the main cabinet, maybe some cu plate will do, so i guess distance wise everything is close, but fully separated shielding wise
Old 4th September 2012, 09:15 AM   #7249
nhinstruments
RCruz's Avatar
MPP
What type of TX do you plan to use ?
RC
Old 4th September 2012, 09:20 AM   #7250
TX ?
MPPHide this!Advertise here!
