Old 3rd September 2012, 05:11 PM   #7211
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by Joachim Gerhard View Post
Everybody will tell you that his solution is the best and so it should be. Have fun !!!!
I am far from stating mine is the best solution but using a simple hexfred bridge before 15000u smoothing Nichicon caps allready makes it sing.
I believe some coils would improve on this thou.
RC
Old 3rd September 2012, 05:29 PM   #7212
RCruz's Avatar
Now a different story... I am using an old Micro TT that I found in the house I am now living in... It needed some work ... cleaning, new belt, bearing tightening and motor refurbishing. Now it works and sounds very good indeed. It is a very well built machine but an entry level with a very torquy motor that produces some vibration and noise.
Today I decided to experiment it connected to my Ricgeddon (a 220 to 110v 500VA toroid followed by some resistors to lower mains from 220 to around 80vac).
Now the platter takes some more time to reach full speed but does not need a hand start. The good news are: I do not hear or feel any more motor noise.
Results are incredible... micro detail much more aparent, bass more pronounced and a sense of ease on the presentation.
Those who have ac motors should try this simple trick... it is incredibly effective.
RC
Old 3rd September 2012, 05:47 PM   #7213
Joachim Gerhard's Avatar
You found the turntable in the house ????? That is incredible !!!!!
Of cause a silent motor is a night and day experience. Thanks for sharing your simple and effective trick.
The common mode coils in Frans schematic i posted are the Talemas from Reichelt.
Old 3rd September 2012, 05:57 PM   #7214
RCruz's Avatar
I also found a violin hehe
It seems no one cares about turntables around here and this is really a rare find.
PS: I believe the idea to reduce AC voltage came from Naim for the Linn.
It works perfectly with Rega TT also.
It is incredibly effective.
PS: thank you for for the talema tip. I will try it and report the results.
RC
Old 3rd September 2012, 06:03 PM   #7215
Nick77 is offline Nick77  United States
Cant find the Talemas, is this a suitable replacement?
B82733F2701B001 EPCOS | Mouser
Old 3rd September 2012, 06:17 PM   #7216
That Epcos is a good find. Seems to be even better in quality.
Old 3rd September 2012, 06:31 PM   #7217
Please post a picture of the violin (and the TT).
Old 3rd September 2012, 06:31 PM   #7218
phi is offline phi  Sweden
Digikey version
http://www.digikey.com/product-searc...82733F2701B001
Old 3rd September 2012, 08:02 PM   #7219
Holger Barske's Avatar
Had another thought on this common mode choke thing and talked to a good friend of mine, someone who knows a lot more about chokes than me.
To put it short: Forget it. You can't use common mode chokes in the DC section of the PSU (aka behind the rectifier).
The reason for this is simple: common mode chokes are for filtering common mode components. The ripple currents on the plus and the minus lines of a PSU aren't common mode - they are just the opposite (given an identical load in both lines). So you might have the brillant idea to reverse one of the coils to have common mode ripple.
The problem is: if you do so, you also reverse one of the DC currents through the core. So both DC components won't compensate any more, they will add up.
Which leads to massive saturation of that tiny core. Result: Your inductance is gone. Your common mode choke won't do any harm, but it won't have any effect on the signal at all.
Forget about common mode chokes, use seperate chokes for each of the two power lines.
Best regards: Holger
www.holgerbarske.com - Deutschsprachiges Paradise-Support-Forum
Old 3rd September 2012, 08:20 PM   #7220
Amen.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
