Mpp
Mpp
Old 2nd September 2012, 10:23 PM   #7161
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
We discussed that before. A big transformer does no harm besides the possibility to couple more HF, RF into the circuit then a smaller one. Others claim that big transformers have more slam and grunt.
Old 2nd September 2012, 10:25 PM   #7162
quan is offline quan  Australia
Ok thanks
Old 3rd September 2012, 04:31 AM   #7163
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Holger Barske View Post
I will have to get rid of 30 Volts with an passive LCLCLC thing.
yikes.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 3rd September 2012, 06:20 AM   #7164
Holger, something like this :AQvox-Tuning | Holger Barske
Old 3rd September 2012, 06:31 AM   #7165
I have shown it several times but for the new comers here it is again:
I use the Preregulator from my Opus Magnum Phono Stage.
Because Block does not have 2 x 24V transformers i use 2 x 2 x 12V per side where i put the windings in series. The diode bridges are IXIS Silicon Carbide snubbert with REL teflon caps. The 10.000uF caps are slit foils, today i would use Mundorf 4 pole. The common mode chokes are from Lundahl. Loaded, the supply puts out plus-minus 30V, the maximum i recommend for the Paradise R3.
Old 3rd September 2012, 07:37 AM   #7166
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Fantastic prereg... it must provide really good dc for the shunts.
Have you ever tried Jensen 4 poles ? IMO these permit great gains in trebble detail even when powering shunts.
RC
Old 3rd September 2012, 07:44 AM   #7167
No, i use Mundorf, mainly because i have a long busyness relationship to those guys and they are very helpful and friendly. I found the Mundorf 4 pole major in dynamics. I also use them in my power amp and the difference they made was huge. Especially in the bass.
Old 3rd September 2012, 07:46 AM   #7168
Some time ago i posted some measurement i made on my prereg. The waveform before the common mode coils looked like a skewed triangle and after the coils it was much smoother. I really recommend a coil solution.
Old 3rd September 2012, 07:48 AM   #7169
On the right side of the top Lundahl coil, in the cast cabinet you can see my low cost pre regulator. It uses Talema ferrite coils. The Lundahls are very expensive.
Old 3rd September 2012, 08:05 AM   #7170
nhinstruments
RCruz's Avatar
Mpp
They really look splendid these Lundahl... it is normal they have a high price tag
I will try to find those talema coils... what values do you recommend ?
RC
MppHide this!Advertise here!
