| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#7151 | |
RC |
#7152 |
Good to know.
#7153 | |
2x 110mA burning 2x 30mA delivering 2x 80mA.
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#7154 | |
#7155 |
Just ordered two of theese, hope it will do for the paradise
![]() 2*20v 20va |
#7156 |
They will work. A good pre regulator with coils takes care of the HF. Just make sure they do not stray into the circuit, so a separate box is the way to go.
#7157 |
My thought was to make a box in the box from cu plate, to avoid too many boxes standing around
I have one more trafo for the linestage.
#7158 |
Of course. 110 mA CCS setting minus 80 mA real deal makes 30 mA difference to be absorbed by the shunt, not 50. Sry for the bad math.
As I am going to use a 2x40V O-core transformer per channel, I will have to get rid of about 3,3 VA or 30 Volts at 110 mA with an passive LCLCLC thing (or so). Should be possible.
Best regards: Holger www.holgerbarske.com - Deutschsprachiges Paradise-Support-Forum |
#7159 |
I dont want to overload the powergrid in my small country
#7160 |
Hi , i have four left overs trannies each multitap but only single out put rating (9-30VAC)60VA each. Is this overkill?
quan |
