MPP
MPP
Old 26th August 2012, 05:56 PM   #7111
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by Joachim Gerhard View Post
Yes, keep them short, happened to me too and then i simply bend them over a bit...
terrible fix...
Ok so that is another one for Guide
Hessener could you send what you have for now so we can chip in.
Old 26th August 2012, 08:59 PM   #7112
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
terrible fix...
That happened to me also... I forgot
I corrected it on the second channel.
A build guide will be welcome.
1st.... place all resistors.
1st.... place all NPN
2nd... place all PNP
Be carefull to keep low riding ones beneath the heatsink
3rd.... place diodes and small caps and light emiting diodes (measure all diodes before implanting)
4th.... trimmers
5th.... opamps
6th.... small EL
7th.... heatsink with power trannies
8th.... big EL
This is only a first approach.. should be finetuned with all intervenients opinions and best practices.
PS: Remenber there is need to GND connection in the riaa case for the arm GND wire (unless you use a rega or other thing that uses left channel gnd as arm gnd)
RC
Old 26th August 2012, 09:03 PM   #7113
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Good start for a guide. I appreciate your effort.
Old 26th August 2012, 09:09 PM   #7114
nhinstruments
RCruz's Avatar
MPP
hehe
You should see the Bib guide
RC
Old 26th August 2012, 09:15 PM   #7115
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
After Test-Clamping with the actual cooler,
one has to observe how short is usefull.
If one shortens to much, the clamps are useless.
preregulatorpeterE-MAIL
Old 26th August 2012, 09:30 PM   #7116
Peter, we talk about the trannies UNDER the cooler, the little BC ones.
Old 26th August 2012, 09:45 PM   #7117
Benedetto's Avatar
Thanxalot Joachim, but:
I am talking of the other ones.
Old 26th August 2012, 10:08 PM   #7118
You are always talking of the other ones (:
Old 28th August 2012, 06:24 PM   #7119
Banned
For the big ones on cooler
I first fitted the transistors to cooler before welding
One may start form sides or middle fit first one nice and square twiddle in place position the second one take out and clamp repeat till lot is in and then weld
Or, found it after, weld in place transistors and then use magic tool like in picture to clamp
IMO this is the most difficult part of build so take your time as clamps are a pain to get off.
Old 28th August 2012, 07:02 PM   #7120
nhinstruments
RCruz's Avatar
MPP
I prefer to lay the power trannies on the heatsink, then fix them with the springs, then point them into the holes, fix the heatsink and finally solder everything in place.
RC
MPPHide this!Advertise here!
