| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#7081 |
In my system i handle rumble in a different way. My main panels are rolled off under 80Hz with a line filter of 6dB octave. They are down -15dB at 20Hz and -21dB at 10Hz.
Then i have an active sub that is Mono. The sub has a subsonic filter ( 18dB ) under 18Hz and some other tricks. Excess Cone movement is nill. That may be one answer why i do not suffer "Soundstage Shrinkage ". Last edited by Joachim Gerhard; 26th August 2012 at 02:50 PM. |
#7082 |
diyAudio Chief Moderator
#7083 | |
#7084 |
Have edited my post : "rumble" and -15dB at 20Hz, - 21dB at 10Hz
#7085 | |
The tuscany "likes" 470r.... anyway it is good to know.
RC |
#7086 |
Transformer loading is different from resistor loading. To reach 470 Ohm you would need an enormous secondary impedance and that may not damp the transformer optimally.
#7088 |
Here you can find information about the Sowter that i use sometimes. It is a good one besides Lundahl and Jensen. I have personally no experience with Cinemag and Haufe.
I tried Pikatron in the old times. |
#7089 |
#7090 |
You may get a super sonic overshot when you load the transformer light that can sound very attractive.
