Mpp - Page 697 - diyAudio
Old 22nd August 2012, 10:21 PM   #6961
Joachim Gerhard's Avatar
I asume 470 Ohm.
Old 22nd August 2012, 10:24 PM   #6962
pdul is offline pdul  Denmark
Are there any complications with using 100ohm cartload?
Old 22nd August 2012, 10:25 PM   #6963
No, the lower the load the less the input offset. I think i use 200 Ohm for my Lyra Titan i.
Old 22nd August 2012, 10:27 PM   #6964
Mine is a Dynavector karat17 d2
Old 22nd August 2012, 10:32 PM   #6965
I did some more listen today.
Do yourself a favor and get Kate Bush, Director´s Cut.
For example the song : Lily.
Steve Gadd on the drums and John Giblin on bass wreck havock and break loose heaven and hell on this surprising rocking piece.
It is not particular fast like Metallica or such but the rhythm is such penetrating that it blew me away. It goes so deep that i felt like pushed under water, unable to breath.
Old 22nd August 2012, 10:35 PM   #6966
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by RCruz View Post
The yellow cap is my fav... Polystyrene on tin foil...
Me need eye check, they look uncanny like RelCap TFT, teflon & tin
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 22nd August 2012, 10:36 PM   #6967
As far as i can tell the Dynavector has a DC impedance of 32 Ohm and loading recommended is 100 Ohm. That will work with the Paradise.
Old 22nd August 2012, 10:43 PM   #6968
I still have a problem with the matching of the BC`s. I now have 200 pnp`s with hfe 300-390 and 200npn`s with hfe 460-590 all Fairchilds, so i have now ordered 100 of each from Conrad.de, this time Diotec brand.
Will it be bad to mix the brands, in my effort to find matches?
Old 22nd August 2012, 10:47 PM   #6969
The Diotecs that Frans ordered where fine and he found a lot of good matches.
I mixed brands in my Paradise R2 wild and it works just fine.
Maybe stuff the input stage with the best matches. In the mirror it does not matter much because of the multiplying that goes on there. Even with Hfe of 300 the impedance of the Pardise mirror is so high that it barely matters against the much lower impedance in the RIAA.
Old 22nd August 2012, 10:47 PM   #6970
Perfect
Copyright ©1999-2017 diyAudio
