MPP
MPP
Old 22nd August 2012, 04:45 PM   #6951
Bksabath is offline Bksabath  United Kingdom
Banned
Give us couple of hours (maybe more)
Sneaky look at what you up to from work puter.
Will post what I have on Pre reg (merit goes to the ones that designed thing) me Just mechanic....
One thing is certain you need 2 based on experience.
Old 22nd August 2012, 05:13 PM   #6952
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Here is one of the first (or first I'm not sure) designs MPP #4375
Old 22nd August 2012, 06:15 PM   #6953
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
Thank you.
Now some pics of the working thing:
RC
Old 22nd August 2012, 06:40 PM   #6954
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Looks very good. Are the black beans PPS caps from Japan ?
Old 22nd August 2012, 07:01 PM   #6955
nhinstruments
RCruz's Avatar
MPP
Yes.. amtrans.. They sound ok but I will never use those again as they differ more than 20% from spec and present great variations between samples.
The yellow cap is my fav... Polystyrene on tin foil... quite juicy stuff.
The vertical trim pot I use for cart load is a bulk metal from vishay... quite good.
The 6800u caps are FR and the others are 2200 FM + 470u BG
I am currently rediscovering my LP collection... incredible mixture of detail and integrity.
RC
Old 22nd August 2012, 07:09 PM   #6956
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
MPP
Where is the cart's load resistor? On that little board(?) next to input connector?
Old 22nd August 2012, 07:10 PM   #6957
Good that you like the sound. i experience the same : although the sound is very well resolved and detailed it sound from one cloth too. Did you put in the RIAA values that you calculated or do you use the MiiB tuning ? I think this new FR caps are very good, on par with FM and even higher life expectancy.
Old 22nd August 2012, 07:12 PM   #6958
nhinstruments
RCruz's Avatar
MPP
The cart load is in the midle of the board next to input wire connection Salas.
I used my choice of values for the Riaa... Voices are really true
RC
Old 22nd August 2012, 08:11 PM   #6959
What amount of loading sounds best in your setup ?
Old 22nd August 2012, 08:23 PM   #6960
nhinstruments
RCruz's Avatar
MPP
Depends on the cart.... 1k with DL160.... around 470k with DL103... did not try the Benz because of the offset (I did not install the local loop yet)
RC
MPPHide this!Advertise here!
