MPP
MPP
Old 19th August 2012, 01:19 PM   #6851
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Silent... no hum no noise.... Powerfull effortless presentation... Very good bass delineation... Aparent micro dtail... sweet mids... first crude impressions...
RC
Old 19th August 2012, 01:21 PM   #6852
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Ende gut alles gut. I am so happy that you got it working Ricardo ! That is what i said, when you stuff the new Pardise correct it works right away.
Old 19th August 2012, 01:36 PM   #6853
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
MPP
How high is the assembly including heatsink? Can it fit in 1U box?
Old 19th August 2012, 01:39 PM   #6854
The bigest vertical object is the heatsink unless you use very tall electrolytics. I will measure them in a minute.
Old 19th August 2012, 01:43 PM   #6855
You need at least 5cm of height inside.
Old 19th August 2012, 01:53 PM   #6856
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
There goes any fantasy of a balanced MPP set with a floating RIAA
Old 19th August 2012, 02:08 PM   #6857
Jacco, i did not tell anybody so far, but with 2 boards per channel ( 4 in total ) you can set up a balanced Paradise. If that is more perfect then a single Paradise i can not tell. Two grilled chicken in each mouth a day ?
Old 19th August 2012, 02:22 PM   #6858
Salas's Avatar
MPP
Old 19th August 2012, 03:09 PM   #6859
Mr Gerhard,
at least it will be Privat-Paradies
I can't think of any examples of balanced phono stages with true dual complementary inputs, let alone with twice the already sturdy power consumption of a single-ended board.
(maybe two quails each day, with varying sauces, not just truffle and foie gras)
Old 19th August 2012, 03:12 PM   #6860
Sampler has drawn up something like that some time ago. It was called the Masterpiece.
It will be huge though.
MPPHide this!Advertise here!
