Mpp - Page 685 - diyAudio
Old 17th August 2012, 01:22 PM   #6841
Joachim Gerhard's Avatar
Nice scope, Frans.
That cap looks cool, Hesener.
Old 17th August 2012, 02:37 PM   #6842
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by hesener View Post
That should work like a charm - don't know why but I was envisioning something like this:
What is the capacitance range ?
RC
Old 17th August 2012, 03:06 PM   #6843
FdW is offline FdW  Netherlands
FdW's Avatar
Originally Posted by Joachim Gerhard View Post
Nice scope, Frans.
I was attracted to it due to its 12bit vertical depth possibility and the large screen.
Analog digital converter (A/D)
12 Bit at ≥ 5 s/div
8 Bit at ≤ 2 s/div
Old 17th August 2012, 04:52 PM   #6844
RCruz's Avatar
Just finished and fired the Paradise... Not again !!!
I have got one channel working perfectly and the other one outputs 15V
Where should I start ?
RC
Old 17th August 2012, 05:09 PM   #6845
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by FdW View Post
Agilent like refresh and screen. If it will prove itself as the 1052 did, it looks like a new hit.
Old 17th August 2012, 05:29 PM   #6846
RCruz's Avatar
Changing opamps does not alter the situation.
RC
Old 18th August 2012, 05:39 PM   #6847
Banned
And I did order
Rigol DS2102 DSO !!Special offer!!
The guys at the ATL have bought 1set (anonymous) and are planning to use the triplicator Triplicator - Red Dwarf Wiki - Tongue Tied on it
As I said do not use triplicator there may be same disavantagges
Old 19th August 2012, 09:18 AM   #6848
MiiB is offline MiiB  Denmark
Glad I have some triplicators in my hidden stash...
now where is it....??
Old 19th August 2012, 12:16 PM   #6849
RCruz's Avatar
Found the error.... Now time to listen
The holes for the k170 are so small, I inadvertedly caused a short between Drain to Gate in the output buffer k170.... result 15V out offset.
RC
Old 19th August 2012, 12:28 PM   #6850
RCruz's Avatar
How did I find it ?
Usin the simulation provided, I experiemnted with numerous shorts until I got the desired offset:
RC
Copyright 1999-2017 diyAudio
