MPP
MPP
Old 16th August 2012, 11:01 PM   #6831
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I ordered a new LCR meter :
PeakTech® 2170 - PeakTech® - Spitzentechnologie, die überzeugt
Old 17th August 2012, 06:08 AM   #6833
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
You know that i like buffers. Here is an distortion canceling design by our Dimitry :JFET Follower Amplifier Cancels Distortion
Looks very nice, I will study that, thanks for the link.
Old 17th August 2012, 06:10 AM   #6834
FdW's Avatar
MPP
And I did order
Rigol DS2102 DSO !!Special offer!!
Old 17th August 2012, 07:53 AM   #6835
Bksabath is offline Bksabath  United Kingdom
Banned
Do not use the triplicator
The danger is that one version of you the good one is sent far far away
The other even further.
So not a chance to get the 2 to merge and you get stuck with bad one spelling mistakes and all.
Old 17th August 2012, 07:54 AM   #6836
hesener is offline hesener  Germany
MPP
Originally Posted by RCruz View Post
Almost finished stuffing the second board Just waiting for some micas for the power transistors.
Now I am in trouble with the riaa caps... my sourcing went wrong and bought amtrans caps from hificollective... too much variation... need to use big caps I have in stock (REL-CAP 15n) so I will use an external riaa after all.
To connect the external riaa, is it sufficient to connect it to the indicated place in the board or do I need to do some shunts ?
Hi, you can just connect to the place indicated on the board. Important: NO external ground connection, please just connect there and nowhere else. You may want to shield the circuit (depending on how far away you place it) and return the shield to the input ground of the amplifier.
Paradise documents are here: Link list
Old 17th August 2012, 08:01 AM   #6837
MPP
Beautiful ;-)
Old 17th August 2012, 08:21 AM   #6838
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Thank you
It will be a small board just over the existing space.
RC
Old 17th August 2012, 08:22 AM   #6839
nhinstruments
RCruz's Avatar
MPP
I believe optical cables eqiped systems use light amplification to retreive info right ?
RC
Old 17th August 2012, 11:59 AM   #6840
MPP
Thank you
That should work like a charm - don't know why but I was envisioning something like this:
MPPHide this!Advertise here!
