Mpp
Mpp
Old 16th August 2012, 02:41 PM   #6821
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Jacco thanks, you have hidden qualities.
patriz, yes this potmeter is linear. I use Alps blue with middle dent.
Marcin even made a PCB. You can send him a PM if you want information.
Old 16th August 2012, 03:01 PM   #6822
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Almost finished stuffing the second board Just waiting for some micas for the power transistors.
Now I am in trouble with the riaa caps... my sourcing went wrong and bought amtrans caps from hificollective... too much variation... need to use big caps I have in stock (REL-CAP 15n) so I will use an external riaa after all.
To connect the external riaa, is it sufficient to connect it to the indicated place in the board or do I need to do some shunts ?
RC
Old 16th August 2012, 04:09 PM   #6823
FdW is offline FdW  Netherlands
FdW's Avatar
Mpp
Originally Posted by jacco vermeulen View Post
Mpp
Hoplahop ?
Jacco (I am confused/puzzled) why re-posting these links? Hoplahophop
Old 16th August 2012, 04:18 PM   #6824
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
154210-mpp-574.html#post2982127 is not 154210-mpp-115.html#post2982127
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 16th August 2012, 04:38 PM   #6825
FdW's Avatar
Mpp
That's stange, both links (the one Joachim posted and the one you posted) bring me to the same page #574
Old 16th August 2012, 05:13 PM   #6826
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Jacco posted TWO apparently identical posts. The earlier one of these takes you to a different page than does the later one. The problem is the use of abbreviated links.
Old 16th August 2012, 06:25 PM   #6827
With copy & paste such links on the same page, you can do fun stuff with the cache memory on your PC.
Old 16th August 2012, 09:08 PM   #6828
FdW's Avatar
Mpp
Originally Posted by FdW View Post
One small update, the power supply has been fixed. And the LME49710's have been checked. To my amazement thy survived (running on +15 and -25 volts). So the big disasters is in fact not so big at all
Next I have to replace the vas-transistors and figure why I could not set bias (I di suspect one of the driver mosfets). I'l b' b'ck
Another update, it's a amplifier, the bias can be set, the gain is as expected, and (while using the 100 Watt lamp in the power supply) it can (and did) kill a 250 mW 10 Ohm resistor that posed as a loudspeaker
Tomorrow more testing with the lamp in place, and maybe a few watts of music (you see I am getting very careful (maybe a bit to )).
This is all going on very slow due to work being very demanding at the moment, but I am getting there.
Old 16th August 2012, 09:27 PM   #6829
Yes, building high power amps is harder then making low level stuff.
Old 16th August 2012, 09:31 PM   #6830
You know that i like buffers. Here is an distortion canceling design by our Dimitry :JFET Follower Amplifier Cancels Distortion
MppHide this!Advertise here!
