Mpp - Page 678 - diyAudio
Old 14th August 2012, 08:31 PM   #6771
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by Stefanoo View Post
mmmm interesting! What is the sonic impact by increasing the current on the CCS?
There is a turning point... Increasing current in the CCS creates a much bigger sounstage with perceivable microdetail.
RC
Old 14th August 2012, 08:34 PM   #6772
nhinstruments
RCruz's Avatar
So interesting! This also tells me that if we are cabable of hearing something so little, I can't imagine the caps of the RIAA on the Paradise being so insentive to changes.....
I can even hear differences just by changing wires inside my builds.
I am glad you can also hear differences.
RC
Old 14th August 2012, 08:37 PM   #6773
Joachim Gerhard's Avatar
Yes, everything makes a difference but what is the magic combination ?
Old 14th August 2012, 09:08 PM   #6774
Stefanoo's Avatar
I just brought that up to everybody to make people reflect on the fact that although certain things seem to be obviously non-influent on the sonic performance such as cables, power wiring, and other things, at the end of the day, the ear will be able to detect it.
If this is true, how much true must be the effect of the capacitor on the RIAA circuit.
I understand that the principle is very paricular and works back-wards but I can't imagine not being able to hear the difference between two different capacitors of two different quality level.
I will probably be proven wrong until then...let's just wait and (WATERRRR!!!....LOTS OF IT!!!)
Stefano
Old 14th August 2012, 09:13 PM   #6775
nhinstruments
RCruz's Avatar
Come on.... It is a passive filter.. off course differences in caps will be clearly audible... anyway, some prefer teflon on copper, others styrenes on tin foil...
RC
Old 14th August 2012, 09:17 PM   #6776
Stefanoo's Avatar
dumb question:
why the BC BJT series was chosen? For low cost and good performance and widely available?
No-cost object, what would be the best BJT?
I usually use ksa992/ksc1845 which are cheap as well, good performer and replacement for the former Toshiba.
Would those be better, worse or equal replacement for the one chosen here?
Stefano
Old 14th August 2012, 09:20 PM   #6777
Stefanoo's Avatar
maybe you missed the point that MiiB made, which is actually a very good point.
Anyway, I won't get tired of repeating it, nothing beats the Teflon/Copper V-CAPs CuTFT (I have no monetary interest with this just to clarify!).
Stefano
Old 14th August 2012, 09:21 PM   #6778
Benedetto's Avatar
Hi Stefano,
where could be the achievement in using ksa992/ksc1845 ?
preregulatorpeterE-MAIL
Old 14th August 2012, 09:33 PM   #6779
Stefanoo's Avatar
none I just was asking if it could have been an equal replacement (the reason is that I have a ton of those and I would have to order the BC).
Sonically I don't know how the two (BC and K) compare so I can't say!
Stefano
Old 14th August 2012, 09:37 PM   #6780
nhinstruments
RCruz's Avatar
I believe what Miib said is that this design works "in reverse"... the lower the signal the lower the distortion also the higher the freq, the lower the distortion.. It is a current modulated principle.
Differences in caps will be heard, but in what way ?
And I agree with JG... who knows the magic solution ?
It will take time and experimenting to find the ideal solution.
I do believe those vcaps should sound awesome.. others say duellunds are the best solution... it all depends on the implementation.
Some years ago I replaced some connecting wires inside my Meridian 101 with silver wire.. sound became faster but lost all the poise... after returning to the plain mogami, I found nirvana again.
All parts are important in the chain... its all about cooking I guess.
RC
Copyright 1999-2017 diyAudio
