MPP
MPP
Old 10th August 2012, 01:40 PM   #6671
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
I used a 10uF 35V Panasonic FM without problem. I measured the ESR to be around 1 Ohm with this cap.
Told you so
On the other hand, no one has been able to make this thing oscillate so try it and I already did some weird thing to it (including using more than 2 Mtr of intertwined wire between the PSU and the attached electronics).
The point is (and that is why others may advice against capacitor(s) on the output of the shunt) that the capacitor lowers the open loop gain of the shunt and thus may (in fact) up the output impedance. My simulations, with capacitor esr at about 1 ohm, show little of this effect.
Old 10th August 2012, 01:42 PM   #6672
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Originally Posted by FdW View Post
It is not advised to use low (and very low) esr types on the output of the shunt, other shunt designers say that it may even be better to leave the capacitor out. My opinion is that the best practice is to install a 'normal' 'high ' esr type it's purpose is mostly to suppress (lower the output impedance of the psu) at high frequencies (> 1 Mhz). One replacement I would like to see tested is, a 2 Ohm resistor in series with a high quality 5..10 uF capacitor.
On the other hand, no one has been able to make this thing oscillate so try it and I already did some weird thing to it (including using more than 2 M of intertwined wire between the PSU and the attached electronics).
Perfect... I believe a 10u (or less) film in series with 1ohm will work then.
This cap (as well as the one filtering Vref) tend to leave it's signature so a good film cap might do wonders in the output
RC
Old 10th August 2012, 01:47 PM   #6673
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, a film plus 1 Ohm should work. There are really small 10uF Wima MKT that i use.
Old 10th August 2012, 01:55 PM   #6674
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Yesterday evening I have experimented a little bit with a couple of circuits trying to determine DC performance and Noise performance.
While noisewise, they are pretty close to each other, the DC performance of the simple source follower is way better than the big borther (complementary's).
I kind of grasp why the DC performance of the source follower would be better compared to the complementary version.
Nevertheless, my concern is:
Is the Fet version of the Paradise (see picture below) going to have the same DC issue of the complementary version?
What makes the Paradise behave so well DC-wise?
DC performance are really important when the stage is followed by another high gain stage to top off the necessary gain.
What do you guys think?
Stefano
Old 10th August 2012, 01:57 PM   #6675
nhinstruments
RCruz's Avatar
MPP
Super.... Another way to avoid cap signature would be to revise Vref so we could use a 10uF film there also... but that is another story
I believe we could manage if replacing the leds by a HQ resistor....
RC
Old 10th August 2012, 02:32 PM   #6676
MiiB is offline MiiB  Denmark
there's no DC issues with the Fet version, but you cant get enough gain using the servo the way you do.. reason is that you want the servo to have some authority so the output resistor can't be too big, this resistor is in paralleled to the RIAA shunt. which in return affects the RIAA network. max gain with this servo is app 52 dB, you really want app 62-63 dB
In your Fet version you have trouble controlling the current drive and thus the offset, better would be to use the paradise servo-ed housekeeping
Old 10th August 2012, 02:49 PM   #6677
Stefanoo's Avatar
Let me think about what you said and make some more simulations and I will get back to you.
Stefano
Old 11th August 2012, 10:41 AM   #6678
FdW's Avatar
MPP
Originally Posted by Stefanoo View Post
wow.....it must have been exciting to be able to see the original pictures in back and white!!
Too bad she killed herself!
You may have not realized this, I did not , but this was the first post on page 666. http://en.wikipedia.org/wiki/666_(number) see 2.1. For as far as I can see, we escaped further disaster and left the page a bit later
Old 11th August 2012, 10:46 AM   #6679
FdW's Avatar
MPP
No lights yet, here a small status (stupidity) report,
Last saterday the board was compleated, sunday during the day it was mounted, and sunday evening I destroyed it
After first power up I could not set idle current, so I took the meter and the nearest probing pin (it was a (to) large one), and started metering some points. The next thing is, I shorted 70 Volts against the Vas-cascode, this destroyed the cascode and put lots of volts on the opamps... you can guess it from there.
Next weekend there will be time, and the fight goes on ... will be continued ...
One small update, the power supply has been fixed. And the LME49710's have been checked. To my amazement thy survived (running on +15 and -25 volts). So the big disasters is in fact not so big at all
Next I have to replace the vas-transistors and figure why I could not set bias (I di suspect one of the driver mosfets). I'l b' b'ck
Old 11th August 2012, 01:23 PM   #6680
C18 in post 6674 is much too small to suppress noise in the lower regions.
Frans, good luck. I work on a power amp too but much smaller. A 30W bridge for Holgers Solar Panel project.
MPPHide this!Advertise here!
