Mpp
Mpp
Old 3rd August 2012, 05:37 PM   #6551
MiiB is offline MiiB  Denmark
What is the point of a truly linear riaa.... Ok I know the answer to that, but the fact is that records are not cut that precise. This lift makes most records listenable, not only those cut on the warm side of the curve. I'd rather be able to listen to all my records with good result, than have to ditch half, due to an absoluteness to accuracy. To me a Riaa is for decoding the music, not decoding the record...(does it make sense...??
Off course people may alter values as they please, but for most I'd recommend that the slight base lift is kept.
Salas...The impedance of the mirrors here is primarily set by the impedance of the current source driving them, there are two things to say about the mirrors, one is impedance, the other is current gain. The latter determines the offset, the first has influence on the RIAA network. The impedance ha also great influence on the distortion spectra of the RIAA. The current gain balance is set by the two resistors. the better matched they are, the smaller the offset and the less the servo has to work.
Old 3rd August 2012, 06:19 PM   #6552
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
And that is why 99% of my vinyl collection is pure audiophile pressing.
If you are striving for the top quality on the design you can't then put on vinyls pressed and mastered using low quality/old equipment.
Now if just want to listen specific music that you can't find in audiopile grade, then I find my self I am better off listening to it in digital format.
This is just my opinion...
Stefano
Old 3rd August 2012, 06:33 PM   #6553
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Mpp
Talking the 120R ones? Face to face bonding of mirror BJTs non critical?
Old 3rd August 2012, 06:38 PM   #6554
Bksabath is offline Bksabath  United Kingdom
Banned
[QUOTE=MiiB;3113820]What is the point of a truly linear riaa.... Ok I know the answer to that, but the fact is that records are not cut that precise. This lift makes most records listenable, not only those cut on the warm side of the curve. I'd rather be able to listen to all my records with good result, than have to ditch half, due to an absoluteness to accuracy. To me a Riaa is for decoding the music, not decoding the record...(does it make sense...??
QUOTE]
And then consider all the works that happens in the recording studio and all those fancy knobs on the desk and so on and once on tape same more knobs get twisted around just to get the right number of tracks with the right lenght in the limited space a LP offers.
And then the Neuman resistor that never realy had a value to start with
But if one got a precise start point then things wont be much different between extremes.
IMO capacitors at 1% are fine by me I am more concerned with the flavor they may ad (coloration to harsh word for Paradise)
So if teflon is the way count me in for GB but also stiroflex from LCR are prety good, they do brighten up the sound in my personal experiece but then this may be just what my old and worn ears need.
And then I would realy like to try same Z foils for the RIAA as signal go troug those before it ge dumped to ground by the caps
In the mean time sorry if not here to often it is difficoult to leave the Spinner alone latley
Old 3rd August 2012, 06:47 PM   #6555
Stefanoo's Avatar
[QUOTE=Bksabath;3113901]
QUOTE]
I fully agree with you. There are already a lot of compensation durind the process.
So I would stick as much as possible to the standard curve without worrying too much.
also, like you said the most important thing is the sound signature introduced by the capacitors and the Teflon V-CAP CuTFT is the best capacitor I have ever tried period.
If we get to the point to do a group by for these caps and have them on the phono, you will see how good they can sound...they will re-define the standard for capacitors.
Stefano
Old 3rd August 2012, 09:51 PM   #6556
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Just finished sorting the BC's (again) and numbered the board acording to the schematic... Please have a look and let me know if there are no errors.
RC
Old 3rd August 2012, 09:54 PM   #6557
nhinstruments
RCruz's Avatar
Mpp
Hi Miib
What resistors are you refering to ?
RC
Old 3rd August 2012, 11:20 PM   #6558
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
@ all the wise guys,
will there be, one day, a guide to all these, for the innocent fool,
as me ?
In this thread is so much knowledge assembled, it would take another lifetime for me to get rid with it.
Please, if i'm not asking for to much, please, somebody should help us (yes i do think i'm not alone) translate a bit for the dumb.
Let me say, in my opinion, this is by far the best thread i had the joy to follow !
preregulatorpeterE-MAIL
Old 4th August 2012, 12:21 AM   #6559
Poor you....Do you have any idea about the treasures you missing out on...??
Old 4th August 2012, 12:54 AM   #6560
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mr Gerhard still is a breath of fresh air (and he does phono)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
MppHide this!Advertise here!
