MPP
MPP
Old 2nd August 2012, 11:20 AM   #6511
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by FdW View Post
P.S.
Ahh, nothing like a well-dressed cat !
Makes me wonder if anyone ever examined the effect of identical/dissimilar resistor and cap values, with constant RC number.
Old 2nd August 2012, 11:44 AM   #6512
beetle is offline beetle  Germany
Originally Posted by hesener View Post
In my Paradise I matched the two channels to better than 0.1%, using 100pF, 220pF caps (in my case, Wima MKS2) as needed (and of course measuring them all) to combine to the perfect value. Similar for the resistors. This took me around 1hr to get it all sorted, but it really is worth the effort.
What do you use to measure such tight tollerances? Or do you just match the chanels?
Old 2nd August 2012, 12:08 PM   #6513
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by RCruz View Post
Perfectly clear... Thank you so much....
Can we modify the resistors values to "hot rod" the shunt so it works at higher ccs current ?
Yes
Old 2nd August 2012, 12:17 PM   #6514
FdW's Avatar
MPP
Yes
See also my notes in MPP
Old 2nd August 2012, 01:34 PM   #6515
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
It's actually quite impressive what good sound comes from Wima MKS2 caps, with this stage, so if the V-Caps better that, it should be an interesting experiment.... With all the efforts in the input stage and current mirrors and buffer, I think the Paradise will be very transparent to component changes.....
I would think so too.
This is what I am going to do:
When I will get the boards, I will build them up using standard parts (WIMA/ DALE/ PANASONIC FC) measure, listen and cross reference it with other phono I have.
Then I will upgrade with The custom 11n and 32nF Aura T I have in the house.
If the phono will respond the way other piece of equipment responded, I will let you guys know and who is interested can join a group by for the VCAP CuTFT.
Souds like a plan?
Stefano
Old 2nd August 2012, 01:56 PM   #6516
Joachim Gerhard is online now Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Good idea Stefano.
Old 2nd August 2012, 02:15 PM   #6517
The reason i've been buying RIAA caps (1%) by the 100's and K's over the last +25 years.
John Curl's Blowtorch preamplifier
Aah, Freak city, my kind of town.
Shame that almost all old Ossi buildings in Berlin are gone, no more demolition club parties.
Radisson Blu Alexanderplatz (beats me why someone who lives right at the ocean, picks an aquarium hotel )
Old 2nd August 2012, 06:05 PM   #6518
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
There is a difference... It is quite difficult to get a good stable soundstage if you use different resistor, cap values (keeping the same RC number), so I find it very expensive to build a very well matched riaa because I always need to buy 10x times the number of parts needed so I can get almost exact matched parts.
I am experienced in this subject as I have built several passive riaa filters in the past.
I dream about teflons but how much would it cost to have matched pairs with the exact values needed ?
RC
Old 2nd August 2012, 06:17 PM   #6519
Teflon cap manufacture will also fit the Gaussian distribution curve, could become a painfull event at 5% spread.
Old 2nd August 2012, 06:30 PM   #6520
Stefanoo's Avatar
unless you buy them from Parts Conn or direclty from Audience or V-Cap, then you can only buy 2 and precision will be better than 1% ()in my experience most of the time is below 0.5%)
If you know what you want and you know what you need, there is no need for anybody to buy 100s of parts!
Stefano
MPPHide this!Advertise here!
