Old 2nd August 2012, 08:31 AM   #6501
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by hesener View Post
It's actually quite impressive what good sound comes from Wima MKS2 caps, with this stage, so if the V-Caps better that, it should be an interesting experiment.... With all the efforts in the input stage and current mirrors and buffer, I think the Paradise will be very transparent to component changes.....
Those are really good news.... I will build severall riaa circuits to experiment with different kinds of components
I had a wonderfull experiment with Mouser and parts are arriving today ... way cool
I just downloaded the latest BOM from hesener's post on th GB thread... what is the purpose of R104b R204b resistor with X value ?
RC
Old 2nd August 2012, 08:37 AM   #6502
hesener is offline hesener  Germany
these are just to finetune the current of the CCS in the power supply section. In most cases you will not need them, if your power resistors R104, R204 are reasonably good.
typically in shunt regulators you want to set the current at twice the load current, so that you operate well within the sweet spot of the regulator, and that is the case here. So the absolute value of the CCS current does nto really matter much.
but I will leave it to Frans (the PSU designer) to comment.....
Old 2nd August 2012, 08:39 AM   #6503
RCruz's Avatar
Originally Posted by Stefanoo View Post
Ricardo,
I guarantee you that the V-Caps CuTFT are the ultimate in terms of sound quality!
Nothing can beat them in terms of precision, transparancy, 3D, musicality.
You should join us, you would be surprised with it.
Anyway....of course...I will post the final simulation for yours/ everybody's enjoyiment.
Thank you so much.... As you can see, my calculations give similar results to your simulation
RC
Old 2nd August 2012, 09:37 AM   #6504
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Accuracy of all these PTFE caps is 5%, how were you going to solve that ?
Not so much,.......if it says "ZM" in the corner.
Old 2nd August 2012, 10:39 AM   #6505
beetle is offline beetle  Germany
A while ago I recommended micas from Jahre. They also do build to order. I think 1% is no problem. Why not go for them?
http://www.jahre.de/index.php?id=61
Old 2nd August 2012, 10:57 AM   #6506
FdW is offline FdW  Netherlands
FdW's Avatar
There are 3/4 parts that set the CCS current: Led L110, Vbe Q102 and R104/104b.
The CCS current = ( V(L110) – Vbe(Q102) ) / R104.
Some of these (all ) are a bit imprecise and may lead to slightly different currents in both CCS’s, to adjust these and ‘not needing to change the bulb’ – sorry replace the resistor (and possibly damage the board) an optional parallel resistor was introduced.
To make currents in both CCS’s equal, add power , measure the voltages across the resistors R104 and R204, then (for the side with the highest voltage) calculate the current Ih = Vh / Rh . Then for the side with the lowest voltage calculate a resistor Rl = Vl / Ih. (where h=High side, l=Low side).
Next we need to calculate the parallel resistor to introduce, 1/Rx = 1/Rl – 1/Rh.
I hope that this is clear
P.s. http://www.youtube.com/watch?v=Qa_gZ_7sdZg
Old 2nd August 2012, 11:09 AM   #6507
RCruz's Avatar
Richard Jahre GmbH: Bauform 53
Micas can sound stark... I only use them to "top up" and reach optimun values. They match well with larger vaules polypropylenes.
If the 11n are not carefully matched between channels, you might get an audible difference similar to gain difference between cahnnels.
RC
Old 2nd August 2012, 11:11 AM   #6508
In my Paradise I matched the two channels to better than 0.1%, using 100pF, 220pF caps (in my case, Wima MKS2) as needed (and of course measuring them all) to combine to the perfect value. Similar for the resistors. This took me around 1hr to get it all sorted, but it really is worth the effort.
Old 2nd August 2012, 11:11 AM   #6509
RCruz's Avatar
P.s. Blue alert - Red Dwarf - BBC comedy - YouTube
Perfectly clear... Thank you so much....
Can we modify the resistors values to "hot rod" the shunt so it works at higher ccs current ?
RC
Old 2nd August 2012, 11:19 AM   #6510
RCruz's Avatar
In the trebble cap (11n) I even use 10pF SM to reach a better acuracy
RC
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
