Mpp
Mpp
Old 29th July 2012, 07:21 PM   #6421
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Mpp
(2.5/0.002) Vpp in your asc?
Old 29th July 2012, 08:13 PM   #6422
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
I have a question for the guys here.
I am trying to make the gainstage attached below working with the Servo.
Simulation shows that it works just fine, but when I try to implement it doesn't.
Any comment?
Thanks.
Stefano
Old 29th July 2012, 08:17 PM   #6423
Stefanoo's Avatar
yes, you are correct.
Stefano
Old 29th July 2012, 09:14 PM   #6424
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Stefano, here is a circuit that is similar to the JC Vendetta. Here the servo is connected to the source resistors of the input stage. You are not using a folded cascode so you have to use a non inverting servo in your case. The other option would be to make the second stage cascades floating and connect the servo there.
Old 29th July 2012, 09:17 PM   #6425
Stefanoo's Avatar
Thanks,
in the simulation it shows that if I make a non inverting servo it doesn't work! I wonder why!!
Oh gosh I didn't realize it was so similar to the vendetta!!! anyway thank you I will try it.
Stefano
Old 30th July 2012, 01:35 PM   #6426
hesener is offline hesener  Germany
Mpp
60 sets in the group buy, and counting......
Old 30th July 2012, 04:08 PM   #6427
That is quite amazing. Anyway, it is no mistake to build it. I am happy that after over 3 years in the making the wait is over.
Old 30th July 2012, 04:51 PM   #6428
Stefanoo's Avatar
That's pretty awesome!!!
Good job you guys and thank you for sharing such a woderful piece of work with us.
Stefano
Old 30th July 2012, 04:56 PM   #6429
Stefanoo's Avatar
Joachim,
I am still working on simulation for servo gain stage and buffer.
Does the servo look good?
In this case it is not on the signal path, but I am not sure it could work in practive.
It simulates just fine and with an input offset it acts and zeros the output out.
Would you mind comment it?
Thanks,
Stefano
Old 30th July 2012, 05:30 PM   #6430
MiiB is offline MiiB  Denmark
Instead of the two resistors setting the current you could opt for a current source, this is a replicate of the household I did for the paradise... Now the servo works by injecting current into circuit to make the two halves amplify the same... This is for me an optimal way of implementing a servo, here it work just like an automated trimmer. Will it still work if you make R14/R30 larger....like 47 Kohms...??
I have tried to servo buffers...but somehow it's difficult, with one exception the single ended N-Jfet buffer, To me that is a beautiful design..
MppHide this!Advertise here!
