MPP
MPP
Old 19th July 2012, 01:54 PM   #6291
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Thank you Joachim.
Maybe the malfunctioning shunt is responsible for the absence of sound... strangely the shunts output the correct +-24V but maybe there is not enough current.
RC
Old 19th July 2012, 03:04 PM   #6292
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by RCruz View Post
Thank you Joachim.
Good that you have found the problem, as the output voltage was 24V this problem should not have any problems (other than sub-optimal regulation). P.s. Be shure to check the driver transistor.
Old 19th July 2012, 06:50 PM   #6293
nhinstruments
RCruz's Avatar
MPP
Which is the driver transistor ?
RC
Old 19th July 2012, 07:19 PM   #6294
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That must be a BC near and connected to the TIP31C.
Old 19th July 2012, 07:44 PM   #6295
nhinstruments
RCruz's Avatar
MPP
Perfect, I was planning to replace it as well..... Now letīs see if curing the ccs part of the shunt solves the problem.... I wonder..... I miss my scope.
In the mean time I am collecting parts for the R2
RC
Old 22nd July 2012, 03:57 PM   #6296
nhinstruments
RCruz's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
In total the values are :
11nF
33.3nF
9.1k
73.5k
Reading the boom that Hesener sent I have the same values but in the schematic, the values are different.... Is there a final schematic with the correct values for paradise r2 ?
RC
Old 22nd July 2012, 04:34 PM   #6297
I used the values in post 6296 and got results that i posted. That are my official values.
0.75dB plus in the bass and 0.25dB plus in the treble. That was a deliberate choice by MiiB and me. Getting away the 0.75dB gain at 20Hz is easy. Just make the 73.5kOhm resistor a bit smaller.
Old 22nd July 2012, 04:35 PM   #6298
nhinstruments
RCruz's Avatar
MPP
Sorry... just found it hidden in hesennerīs box
RC
Old 22nd July 2012, 04:45 PM   #6299
No problem, this is a complex project and got even me confused at times. The R2 on the other hand is a very good stage where all contributors can be proud of.
Old 22nd July 2012, 04:58 PM   #6300
nhinstruments
RCruz's Avatar
MPP
I am working on it now...
As for the non working original paradise, I have bad news.. removing the power transistor from the shunt was a disaster.. the pads lifted making it impossible to replace.. I will leave it as is for now.
RC
MPPHide this!Advertise here!
