Old 28th June 2012, 10:40 AM   #6111
Bksabath's Avatar
I am going to take shorth break from puter and then tidy up
I can send you copy of Mouser chart later (hope to get it finished this eve)
I can also send you curve tracer matched sets of BC337/40 and BC327/40 with HFE of around 540 for fair price.
Just PM with your Email...
Old 28th June 2012, 10:55 AM   #6112
Benedetto's Avatar
Thxalot (forgot your name),
for the BC's, i've got my share from Frans.
Looking forward to the Mouser thing...
Take your time.
preregulatorpeterE-MAIL
Old 28th June 2012, 03:35 PM   #6113
hesener is offline hesener  Germany
Originally Posted by Bksabath View Post
No to worry here is another one...
Hessener
What Type of 1 uF capacitors are in the picture of post 6055?
Wima MKS2, 1uF 50V DC, check out 42D2850 at buerklin.com
Old 1st July 2012, 06:24 AM   #6114
Bksabath's Avatar
Tanks hesener
I was pretty sure of that, as I could not find MKP on that footprint.
I have already quite a few MKS 2.2 uf from buerklin any detrimental reason not to use those?
Old 1st July 2012, 08:44 AM   #6115
Tanks hesener
these should do fine. please remember that the caps in the shunt regs and the servo should have 1uf as per schematic, else you are changing the time constants. the other caps are optional, 2.2uf should be fine. the footprint is 5mm but you can drill further holes to make them fit (watch that ground plane for accidental short circuit, though). DC voltage rating should be 30V min.
you may have notednthat the holes for the power diodes in the shunt reg are a little tight, thats already fixed....
let us know how you progress, any issue with the betabuild please drop me a line so I can fix the PCB......
have fun!
Old 1st July 2012, 09:26 AM   #6116
Bksabath's Avatar
Tanks hesener I will get the 1 uf I have made same progress with part bom text in red need if you could looking at
I have not included the semiconductors parts
Resistors are IRC type + reccomended parts from your notes
PS
Cut and paste part numbers to mouser will take you directley to those
Old 1st July 2012, 11:42 AM   #6117
Bksabath's Avatar
Originally Posted by hesener View Post
have fun!
Oh yeh
Got pre-reg ond same FiFi raw suply cooking
for preamplifier from bolshy droog on other tread.
Those dudas give prety clean 35V at 140 mA so as I got one set already may as well make second set for Phono stage.
Sorry if taking long was hoping for pre-amp to be finished 2 weeks ago
Raw series Shunt reg
Separate Trafo box with emc filter and ...pre-regulator
Old 1st July 2012, 05:45 PM   #6118
PS
looks good to me. for the 120/3w i used 2w, worked just as well
Old 4th July 2012, 07:17 AM   #6119
How are my fellow beta builders progressing? or is paradise just too hard to leave?
Old 4th July 2012, 07:54 AM   #6120
Bksabath's Avatar
Waiting for delivery of parts and finishing off Pre-Amplifier
When things will start to happen it will be prety quick
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
