MPP
MPP
Old 19th June 2012, 06:28 PM   #6081
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The ATLīs came in the morning into my room and did not let me out until 16.00 ......
Old 19th June 2012, 06:36 PM   #6082
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by Benedetto View Post
Hello Frans,
it was a pleasure to meet you @ FF.
But you disappeared so quick.......
About mounting Torque.
Are you sure a tiny little M3 screwed in a Aluminium-
cooler will be able to withstand this load ?
In my little experience i'm not as sure.
Sorry,
i've had to read before i speak.
And here is an calculator Bolt Ultimate Strength Calculator
12.9 (alloy steel, quenched and tempered with a minimum UTS of 1220 MPa) or,
8.8 (carbon steel quenched and tempered or carbon steel with additions of boron or chromium or manganese, quenched and tempered) with a minimum UTS of 800 MPa (up to 16 mm diameter - the figures used in the calculations, although above 16 mm diameter 830 MPa UTS can be assumed).
Bolt diameter: 3
Thread pitch: .5
Bolt grade: 12.9
Answer (Bolt ultimate strength in N): 6137
Old 19th June 2012, 06:41 PM   #6083
FdW's Avatar
MPP
God will know ... The God Computer Kindle eBook by David Newstead (3 times)
Old 19th June 2012, 09:23 PM   #6084
as_audio is offline as_audio
Originally Posted by FdW View Post
FrickelFest = Diy for men (mostly)
More about those washers can be found here: Disc Springs to DIN 2093
(4)
DIN 2093 - Tellerfedern
Old 19th June 2012, 11:05 PM   #6085
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Hello again Frans,
sorry, i'd missed your Edith.
A strong bolt is, i think in any business,
the Alpha and Omega.
To speak about those ATL little Greys,
judged by the stains, i think they've treated
him really mean.
But, as anytime, he'd absorbed 'em.
preregulatorpeterE-MAIL
Old 19th June 2012, 11:27 PM   #6086
Benedetto's Avatar
Shortly after the construction of the poodle itself, GOD made TWO big mistakes. The first one was called MAN, and the second one was called WO-MAN.
Old 20th June 2012, 02:30 PM   #6087
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Just received my second paradise boards and am now preparing to source the components.
I found the BC327 and 337 in Conrad.ch from Diotec semiconductor... Does anyone know if these are ok ?
Hi Frans.. do you still have some of these you could spare ?
RC
Old 20th June 2012, 02:55 PM   #6088
FdW's Avatar
MPP
Default FricklFest, Not a 'drink'-free zone :)
The Diotec versions (that I have) are very good, I can recommend them. And I do not have 'spares' left, sorry. Maybe you should organize a little group bye (as I did) and get them for about 1.5 Euro cents (1000 pcs) at BC327-40TAPE DIOTEC | SOS electronic
Old 20th June 2012, 02:57 PM   #6089
nhinstruments
RCruz's Avatar
MPP
Thank you Frans
RC
Old 20th June 2012, 03:06 PM   #6090
Hello Ricardo !
I see that you are now in Switzerland.
MPPHide this!Advertise here!
