MPP
MPP
Old 23rd May 2012, 09:32 AM   #5911
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Well actually i would prefer a bit more gain so i will try 2 x 100 Ohm.
Old 23rd May 2012, 04:11 PM   #5912
I rebuild the input stage of the little Pre-Pre to Frans circuit. It works very well. Hum is really zero and the sound got better too, more musical and warm and less dry and over controled. Noise is not audible at the listening place at high volume so my concern was over carefull. I also designed a fitting shunt feedback RIAA. The ADA4898 can deliver 40mA clean so i am using a PhonoClone circuit with much reduced impedance for lowest noise of the second stage. There is an AC and DC coupled version with servo. This little project on the side got me really exited : We have now a Balanced Super Simple Phono Clone that can be fitted close to the cartridge.
Old 23rd May 2012, 04:35 PM   #5913
Sorry, C2 is wrong, it is 29nF.
Old 23rd May 2012, 04:36 PM   #5914
There is another mistake, "Servo" over the second Opamp should read "RIAA".
I get lazy.
Old 23rd May 2012, 08:15 PM   #5915
hesener is offline hesener  Germany
MPP
you could call it "phono-clonika" for all those linn fans out there.... they might want to put it in their LP12's......
Old 23rd May 2012, 08:33 PM   #5916
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Excuse me Al,
ain't "Klonika" closer to their syntax? ;-)
preregulatorpeterE-MAIL
Old 23rd May 2012, 08:47 PM   #5917
OK, we call it the Klonika.
Old 23rd May 2012, 08:51 PM   #5918
Benedetto's Avatar
hello j,
may i call you up tomorrow on a certain question ?
Old 23rd May 2012, 09:24 PM   #5919
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Now change that active RIAA to a passive one and you get this http://www.diyaudio.com/forums/analo...ml#post2162960 (almost)
Old 23rd May 2012, 09:25 PM   #5920
No, it has a 14dB dynamic range disadvantage at 20kHz. I really prefer shunt.
MPPHide this!Advertise here!
