MPP
MPP
Old 22nd May 2012, 08:42 PM   #5901
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Here we go :
The SSTPP, super simple transimpedance pre pre.
The 22 Ohm and 330uF cap decoupling i learned from Bonsai.
It works also without the 22 Ohm resistors but they give a good measure of PSU rejection in the treble where PSU rejection in Opamps is limited.
I forgot a 100nF from Pin 4 to Pin 7. I prefer the single decoupling cap solution, that i copied from D.Self. It works as well as two to ground and is more economical although this 10 cents may matter more in England then they do where i live C:
Well actually the argument is not to shunt into ground but bypassing the chip.
There is a 50 Ohm resistor at the output for stability into capacitive load. The ADA4898 can swing around more current then most so even 20 Ohm is more then OK.
The feedback resistor is 100 Ohm, the highest value recommended to avoid peaking in the highest reaches. With a Denon DL103 with 40 Ohm gain will be to low. Then you have to increase the feedback resistor say to 500 Ohm but then a cap has to be placed parallel to that bigger resistor. I found that surprising small caps like 10pF make the deal. The circuit is DC coupled without servo without problem. Maybe a very high impedance of the cartridge may cause some offset. That can be balanced by putting the same amount of resistance then the cartridge has from Pin 3 to ground at the expense of 3dB more noise.
Old 22nd May 2012, 08:56 PM   #5902
What is this animal ? http://www.ti.com/lit/ds/symlink/lmh6554.pdf
They come faster then i can digest the spec sheets.
OK, it runs on only plus-minus 5.5V and draws a lot of current but watch the slew rate and the bandwidth !
Old 22nd May 2012, 09:05 PM   #5903
sampler is offline sampler  Lithuania
Thanks guys, I did my best with limited time and budget that I had for this one.
There is always temptation for 4 layer pcb, custom xformers or other exotics but I resisted as much as I could
Old 22nd May 2012, 09:07 PM   #5904
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
Here we go :
Joachim, why not VF2 direct to pin 3, then disconnect pin3 from ground, add a 100 ohm resistor to ground (from pin 3). It should improve common mode noise picked up in the cartridge and cartridge wiring. Can you give it a try? And a 100 nF between pin 4 and 7.
Old 22nd May 2012, 09:10 PM   #5905
FdW's Avatar
MPP
Originally Posted by sampler View Post
Hi guys,
glad to see you are making progress with paradise and all the fuss is back to this thread
I dropped by to post my final build of Joachims naked truth. ...
Very, very, very nice build, where is my 'I like it'-button.
Old 22nd May 2012, 09:17 PM   #5906
Yes Frans, that will improve the performance. I will try it.
I am not sure if the 100 Ohm will worsens the Signal-Noise. Maybe not because the input is shorted by the cartridge.
Old 23rd May 2012, 08:41 AM   #5907
FdW's Avatar
MPP
I have to eat the humble pie, after reading your post more carefully I see that you did mention the 100 nF and the 100 Ohm.
http://en.wikipedia.org/wiki/Humble_pie
Old 23rd May 2012, 09:02 AM   #5908
FdW's Avatar
MPP
Joachim, I ran this through the simulator. For equal gain you need (in 'balanced' mode) to halve the resistor value. The resulting noise is equal to the original version.
Old 23rd May 2012, 09:29 AM   #5909
FdW's Avatar
MPP
And because 'a picture tells more than a thousand words'
Old 23rd May 2012, 09:31 AM   #5910
OK, fine, i will try that, so 2 x 50 Ohm.
MPPHide this!Advertise here!
