Mpp - Page 542 - diyAudio
Old 13th February 2012, 10:00 PM   #5411
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
pin 2 -6mV
RC
Old 13th February 2012, 10:02 PM   #5412
Joachim Gerhard's Avatar
Measure that voltage over R45-46.
Old 13th February 2012, 10:02 PM   #5413
nhinstruments
RCruz's Avatar
pin 4 -17v
pin 7 +17v
RC
Old 13th February 2012, 10:03 PM   #5414
That is ok.
Old 13th February 2012, 10:07 PM   #5415
nhinstruments
RCruz's Avatar
15 v
16 v
RC
Old 13th February 2012, 10:14 PM   #5416
That is too much, the servo is run out of "authority".
Old 13th February 2012, 10:15 PM   #5417
You have mesured that voltgae over R45-46, so from resistor input to resistor output ?
Old 13th February 2012, 10:20 PM   #5418
nhinstruments
RCruz's Avatar
yes
on the good channel I read 1.4v and 2.5v on the same resistors
in the bad channel i read 15 and 16 not steady
RC
Old 13th February 2012, 10:36 PM   #5419
Around 2V is optimal so the good channel is just fine.
The servo hits the end stops in the bad channel and can simply not supply more voltage.
Here is something very wrong. i simply have no idea what that could be.
Old 13th February 2012, 10:49 PM   #5420
nhinstruments
RCruz's Avatar
Well, the output oscilates a lot, so it does not seem like a short circuit
RC
Copyright 1999-2017 diyAudio
