| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#5382 |
I am back for a moment. I am listening to the Diamond Dove. I got it working on both channels today.
#5383 |
No, because we are trying to change the voltage at TP4 relative to the emitter voltage of Q27. Lowering the rail will decrease both voltages by approximately the same amount.
#5384 |
Thank you for your help ungie, I believe we are very near to sorting this out.
Unfortunately I can not keep working tonight so I will measure the points tomorrow. Now I see the objective of raising R34... it will be very easy
RC |
#5385 | |
Andrew |
#5386 |
#5387 |
That is my solution to solve the noise issue in MC Phono Stages. The best stages have around 0.3nV Hz. Like the JC Orion, the big Pass and the Accuphase. With bipolars or Fets,
no matter what, you reach a kind of thermal limit at ca. 5 Ohm. Also you have a rise at lower frequencies, that is 1/F noise, worse in Fets then in bipolars. Bipolars have shot and flicker noise. The BC327-337 are actually very good in that regard. Usually the trick to lower noise in active stages is to use many elements in parallel ( Faulkner circuit). At around 8 in parallel the mentioned effects comes into place and paralleling more is not productive any more. One reason is that you can not have infinite gain in the input stage. The detailed physical reasons go beyond posting on the Net. The best source of information is Burkhard Vogels book "The Sound of Silence". I recommend to buy it and read it. It is hard bread though. My solution is a passive I/U converter that is part of a special feedback structure that i call forward coupling. It is not feedforward and it is not error correction. It is not NFB, neither passive or transimpedance like we do in the Paradise. In my system the micro information is directly coupled to the output and nowhere shunted to ground or send back to the input for feedback. It is balanced-floating-differential. The signal from the cartridge is not connected to ground and also not referenced to ground like in a conventional balanced stage. This is not for DIY, mind you, but i think it is interesting to publish the measurements. It has no 1/F so the S/N is maintained in the bass. It has 0,1nV/qHz and a noise impedance of slightly under 0,9 Ohm. The S/N referenced to 1mV is -94dB, 10dB better then any active solution i know. So there is room fore progress. See the measurements. The black trace is the Lyra Titan producing 0,8mV at 1kHz. Because it is a relative measurement you should deduct ca. 10dB. The signal peak is actually at ca. -60dB/V. Red is the Diamond Dove shorted with a special shorting plus. Dark blue is the noise with Titan connected. You can see some hum pickup from the turntable motor and the rise in noise simple because the Titan has an impedance of 6 Ohm. In this case the cartridge produces more thermal noise then my stage. The light blue is 20cm of balanced-shielded cable connected to the stage. that cable is also shorted at the end but still it picks up the motor. When we go that low in noise, cabling and connectors show really bad effects. |
#5388 |
Well, actually, there is a rise in noise in the bass even in my solution that amounts to ca. 10dB, That comes from the active second stage that is already at 1,3nV and has 20dB of gain before it from the passive I/U converter. I COULD parallel active stages too, say 4 for a gain of 6dB, but so what. I do not work for the military and it is not a life critical mission.
It is just for fun and enjoying the music, and music making it does. |
#5389 |
Very impressive! Will this see the light of day in a commercial product at some point?
#5390 |
I build it all myself, by hand. So in a certain way it is not commercial. It is more a customized work of art. I also compensate the cartridge-turntable combination, so that it does fit ideally in a certain system.
I started to think about ultra low noise since 1980. That was the time gallium arsenide transistors where introduced. With liquid cooling i thought this could be much better then Fet`s or Bipolar`s. Unfortunately this kind of transistor has hefty 1/F, so it is very good at RF but not so good at audio frequencies. The noise bug had bit me. It is like audiophilia. It is chronic disease that gets worse with age. Anyway, yes you can buy it. If you sign a subscription and wait for 3 month. I usually give away all that i know and when you have followed this thread and understood 10% of it you are a good phono stage designer and can find your own holy grail. This time i keep my mouth shut, sorry. I found a phenomenon that i have to study in detail. If somebody wants to listen to it, visit me any time. |
