MPP
MPP
Old 12th February 2012, 06:29 PM   #5361
ungie is offline ungie  Canada
Originally Posted by RCruz View Post
Here are my readings hoping to have some enlightening feedback
Can you measure the voltage at the emitter of Q27?
Old 12th February 2012, 06:29 PM   #5362
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Please measure at emitter Q27.
Old 12th February 2012, 06:30 PM   #5363
The idle current in the input stagae is ok.
Old 12th February 2012, 07:56 PM   #5364
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Q27 emitter -13.13
Q28 emitter +14V
The collectors of these should be near zero but they measure 14v
Allready replaced Q28 and Q15 without any changes
RC
Old 12th February 2012, 08:07 PM   #5365
Q27 emitter -13.13
Q28 emitter +14V
You have two voltages written beside TP3 and TP4. Which is the actual one in each case?
Andrew
Old 12th February 2012, 08:14 PM   #5366
nhinstruments
RCruz's Avatar
MPP
TP3 13.3v
TP4 -12.5v
The other values are the ideal ones
RC
Old 12th February 2012, 08:16 PM   #5367
If TP4 is indeed -12.5V and the emitter of Q27 is -13.13V you are close to Q27 not being forward biased and there will be no Ic through Q27.
Old 12th February 2012, 08:25 PM   #5368
Can you measure the voltage at the node between R27 and R6 and also the node between R34 and R29?
Old 12th February 2012, 08:38 PM   #5369
nhinstruments
RCruz's Avatar
MPP
Hi ungie... where are those resistors ?
RC
Old 12th February 2012, 08:47 PM   #5370
nhinstruments
RCruz's Avatar
MPP
R27 to R6 node 18.8V
R34 to R29 node -18.6V
RC
MPPHide this!Advertise here!
