MPP
MPP
Old 3rd February 2012, 04:56 PM   #5101
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
She is always happy when it sounds good.
Old 3rd February 2012, 04:59 PM   #5102
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
So she was on last saturday......
preregulatorpeterE-MAIL
Old 3rd February 2012, 05:02 PM   #5103
Here is the Quad 34 phono section.
Old 3rd February 2012, 05:24 PM   #5104
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
Here are some pictures of the Hulk at ETF2010 taken by Jan Didden. One picture also shows Martina with Garrard and Hulk. The Hulk is also known since as the "Cristal" out of obvious reasons.
Yes Salas, this is one with your Shunts.
I saw Martina using those cristals inside the Garrard TT in Krefel and I also met another guy who sold them and had a really "dead" sounding room full of those..... Piramidal effect ?!
RC
Old 3rd February 2012, 05:25 PM   #5105
nhinstruments
RCruz's Avatar
MPP
My Paradise build is almost completed... just lacking 1uF caps... where can I get those very small caps ?
Can I use tantals ?
RC
Old 3rd February 2012, 05:26 PM   #5106
sampler is offline sampler  Lithuania
Ok, I have to do some catching up here. Circuit in post #5083 on first glance has same problem, T19&T21 with T20&T22 forms high impedance ccs'es and currents are lost again. Will put it in sim to check first. Post #5097 looks promising, were do bases from T19&T21 goes to ?
Old 3rd February 2012, 05:32 PM   #5107
Yes, 5097 will work very well. T19, T21 are ground referenced cascodes. i will draw that part for you in a a minute. If we could drive that cascode too from somewhere is not clear at the moment. In this case i would rather say not.
Old 3rd February 2012, 05:43 PM   #5108
Got it, I will copy that part from T20&T22. Sorry, #5083 doesn't seem to work, finding working points are almost impossible.
Old 3rd February 2012, 05:56 PM   #5109
OK, you where faster and i like your solution better.
Here is what i have drawn up in the meantime, but that is obsolete.
Old 3rd February 2012, 05:57 PM   #5110
hesener is offline hesener  Germany
MPP
Can I use tantals ?
Hi Ricardo, I would not. Tantals are very sensitive to the wrong polarity, and the 1uF is used in the servo if I'm not mistaken so it may see both polarities.... you could put a bigger cap and reduce R48 accordingly, for example.
(have a bunch of these caps, should have put them in the bag to you... if only I had known.... ;-)
Eager to hear what yours sounds like ;-)
MPPHide this!Advertise here!
