Mpp - Page 505 - diyAudio
Old 1st February 2012, 01:18 PM   #5041
Joachim Gerhard's Avatar
One could also not use that resistor at all. The cartridge would then pass the minuscule gate current to the sources and the Fets would then conduct.
Old 1st February 2012, 02:35 PM   #5042
Jacques Merde's Avatar
I could be missing something, but doesn't R12 provide the cartridge load? Would it make sense to retain R12 but place it so that it is connected to the gates and to the node between R112 and R155?
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 1st February 2012, 02:40 PM   #5043
Yes, that is what i just wanted to post ! This is then a floating load. Without the resistor the cartridge is its own floating load, terminated by the low impedance of the negative input, weird. Anyway, a floating resistor would make sure that the Fets conduct, even when the cart is not connected.
Old 1st February 2012, 03:16 PM   #5044
Here is the corrected schematic. Thanks Jacques.
Old 1st February 2012, 05:00 PM   #5045
My pleasure
FWIW, I think this is a really cool project. Thank you for doing it.
Old 1st February 2012, 05:29 PM   #5046
sampler is offline sampler  Lithuania
This looks good Joachim, but I'm afraid I already tried this arrangement and if my memory didn't froze over the day from this weather we are having here there was something fundamentally wrong with it. If I remember correctly fets sources were just swinging in phase with a source without any reference to ground, but I may be confusing something here. Let me put it to sim and get back to you. Or even better, I can try it on real proto.
Old 1st February 2012, 06:04 PM   #5047
Ok, fine, i think it works as strange as it is. We can reference both input to ground though like in an opamp based differential stage.
Old 1st February 2012, 06:34 PM   #5048
Like this : ....
Old 1st February 2012, 06:54 PM   #5049
ok, it doesn't work without cascodes in proto (LF oscilation modulated by input signal with gain on fet's sources, same thing as I tried some time ago), but if I'm getting this right now, cascodes IS the key. Time to build some. I'm assuming some low current K170 instead of "High Impedance Current Source" in your schematics would do for experiments ?
Old 1st February 2012, 07:11 PM   #5050
Sure, they can be casdoded with J310 and then we are in the several tens of megaohms range. The sources of the Fets have to drive the bases and the current source. The higher the impedance of the current source the more drive goes into the bases. For testing one low current 2SK170 is fine.
Copyright 1999-2017 diyAudio
