MPP
MPP
Old 1st February 2012, 01:17 AM   #5031
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default WOW Mr G.
Originally Posted by Joachim Gerhard View Post
Here is a simple idea. The output would be differential of cause so we can not simply sum it for unbalanced. It would cancel. For unbalanced we need a high CMR INA like the Thats 1200. The Fets at the input should be cascoded. This shows only the principle.
Cute !
Audiofanatic
Be nice to animals.
Old 1st February 2012, 01:21 AM   #5032
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, it is very simple. I do not know if it would work exactly like this and we have to check offset issues but it is a start.
Old 1st February 2012, 01:37 AM   #5033
Default Current mirror
I ones did something like this before with the front as is but the output with onlt T11 and T14 and not a RIAA but a simple preamp.
I must look for it, I have it somewhere lying around.
I love current mirrors too
The output had CCS on each transistor leg (emitter ).
Offset was not a problem due to a cap !
Audiofanatic
Be nice to animals.
Old 1st February 2012, 12:25 PM   #5034
I solved the problem with the balanced input and Samplers Mirror-Buffer. It is again so stupid simple that i had to smile. The minus pole of the cartridge simple goes into the sources. The differential INA at the output is now obsolete.
The node between the sources can even have a DC shift against ground because there will not flow current into cartridge. The gates of the Fet isolate that current, so this node can be trimmed for minimum distortion. With the resistor values given ( 5 and 2 Ohm ) and the N-Channels running on 7mA each plus the P-Channels running on 8mA each the offset null and the distortion null fall aprox. in one place.
Old 1st February 2012, 12:26 PM   #5035
I would of cause cascode the Fets. That can be arranged as a driven cascode too.
Old 1st February 2012, 12:56 PM   #5036
Here is the input gain cell.
File Type: pdf Starless Balanced Input Gain Cell.TSC - TINA.pdf (6.6 KB, 127 views)
Old 1st February 2012, 01:01 PM   #5037
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Now you are surfing again... cool
RC
Old 1st February 2012, 01:04 PM   #5038
Jacques Merde is offline Jacques Merde  United States
Jacques Merde's Avatar
The node between the sources can even have a DC shift against ground because there will not flow current into cartridge. The gates of the Fet isolate that current...
If the node between the FET sources is not at ground potential, how do you prevent current flow through R12?
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 1st February 2012, 01:06 PM   #5039
Thumbs up Perfect !
I have to admit it's a different animal !
There is something about it that I don't quite seem to understand, but I'll be back !
I like it.
Audiofanatic
Be nice to animals.
Old 1st February 2012, 01:16 PM   #5040
Jacques, you are right. R12 should be high impedance or the source node trimmed.
MPPHide this!Advertise here!
