MPP
MPP
Old 26th January 2012, 02:15 PM   #4871
MiiB is offline MiiB  Denmark
Input capacitance is 4 times that of the input transistor...BC337 is app 5 pF...So a good guess would be 20 pF... looking into low impedance on the source.. roll-of from this is nothing..
Old 26th January 2012, 02:27 PM   #4872
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
Thanks Michael. http://www.ti.com/lit/an/slyt145/slyt145.pdf
Ricardo, you can grind your mathematical ax on circuit fig.16
It promises accurate RIAA.
I will read it but it seems these use opamps and not an interstage passive filter...
RC
Old 26th January 2012, 02:28 PM   #4873
nhinstruments
RCruz's Avatar
MPP
Much better than with jfets as I expected
RC
Old 26th January 2012, 02:29 PM   #4874
nhinstruments
RCruz's Avatar
MPP
I have talked to Jahre and i got some interesting answers. I wanted to know what the smallest case is with 1% precision for RIAA use. It is case 53.
Here are the dimensions :
6,8nF 125V 12,7 x 12,5 x 3,4 10.2mm between wires Case 53.10
13,6nF 125V 12,7 x 12.5 x 5,3 10.2mm between wires Case 53.20
40,6nF 125V 22 x 12.2 x 10,4 20mm between wires Case 53.50
i get a price quote soon
best, joachim
Looking forward for a quote
RC
Old 26th January 2012, 02:33 PM   #4875
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Well is is actually 8 x , but anyway, BJTs have much less input capacitance ( and hence less open loop distortion ) then J-Fets so this is an advantage of BJTs.
Old 26th January 2012, 02:41 PM   #4876
Yes, Ricardo, it is with Opamps but that is not the point. They argue that a conventional filter has mathematical problems to follow the RIAA exactly and this arrangement of 4 Opamps solved that. I find it intellectual interesting, not more.
Old 26th January 2012, 03:15 PM   #4877
SK170 has input capacitance of 22 pF so this here with a total of 40 pF is roughly the same at one pair of fets, but here we have 4 sets of input devices with much much lower noise and way higher mu..
Old 26th January 2012, 04:31 PM   #4878
The P-channel 2SJ74 has even 105pF. That does really not matter much. An MC cartridge is so low in resistance that the pole created is very high in frequency.
Old 26th January 2012, 04:35 PM   #4879
The transistors have arrived Frans, many thanks.
Old 26th January 2012, 04:54 PM   #4880
mad_z is offline mad_z
We can talk to WIMA. They are in Unna, 80km from my home. I would like FKP2 in 1% with copper or silver wires.
Wima is a good option. I did talk to them some years ago to get special GTO caps for industrial project. They were very helpful and it was not a problem to buy small quantity in OK price.
FKP2 is (so far) copper in RM5 'bauform'. I can get easily 2.5% with no problem but 1% would be much better!!
MPPHide this!Advertise here!
