| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#4651 |
Pre regulator PCB
Common mode to spek 20X30 pin out 100 nF caps 5 mm foot print Beter? I have used 1mm thick tracks agin this can be changed |
#4652 | |
Dear All,
Although our ‘Alien Technology Lab’, short ATL, did say that they would stop working on the 'Area 51' circuit, it seems that some rogue developer(s) continued there obsessive analysis efforts. The results, of the new (unofficial, rogue edition) ATL efforts must be kept secret (jobs may depend on this), so please keep this information to yourself (don not let it out in the open). Attached is the extended ATL circuit collection (circuits L and M added). This ATL technology is freely available to anyone mad (or brave) enough to try it, use the attached files with care. When using any of these ATL findings please add an acknowledgement to ‘Area 51’-component and ATL to your project. Regards, Acting for ATL, Frans. Quote:
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#4653 | |
This has the footprint http://www.reichelt.de/Bauelemente/C...6175882e8ff34c And there are other variations (with more mH's then this one (but less than the first one)) that would fit in that footprint. Regards, Frans.
#4654 |
Bksabath, what kind of electrolytics are you planning ?
I usually use Panasonic FM but others like Rubicon, Nichicon, Frotyth etc. will work well too and should have the same footprint. |
#4655 |
Frans, i like the ones with the switched coils. Do you need a microprocessor to steer this ?
#4656 |
The intention is to have them permanent on (in place) (is what the people at the ATL tell me). The reason for the switches is to remove them from the circuit for performance measurements (it would not be fair to the other circuits, tells one of the ATL developers).
#4657 | |
![]() Actual current ATL hardware
#4658 |
Hi Frans
Tanks Wider traks Agree with you on that. I was also looking at the track going to Q3 and Q7 In my drawing which is a bit long. To keep cost down and ease of home brew I would like to keep the single sided board. Would a wire Jumper bee too bad? Another thing that may be looking up is the choice of capacitors. The MKP 1837 has a pitch of 5 mm. There are alternatives such as the MKP B32625 Epcos, MKP375 BCcomponents,MKP378 those have pitch of 22.5 mm (Farnell stock) Changing from 5.5 to 22.5 for Your SCH C15/C18/C19/C22 would alowd for much larger tracks Altrought with the 5 mm pitch those could and will be increased to at least 2 mm. Don't worry about putting things forward I don't mind making any changes as needed. And got refilable cartriges on printer... |
#4659 | |
Any shape and sizes can be used as you wish There is plenty of space on the board As one of the pins on both sides is to ground al needed is placing a pad on the ground plane. Eventualy we need to consider the board size to reduce waste but still early for that |
#4660 | |
The MKP's would be fine with me, but my say on capacitors should not be definite
