Mpp
Mpp
Old 16th January 2012, 11:39 PM   #4461
FdW is offline FdW  Netherlands
FdW's Avatar
Mpp
Originally Posted by Joachim Gerhard View Post
Not necessary, your Hexfred´s have around 35nsec recovery, i use them too sometimes, the QSpeeds are under 10nsec.
A Schotky has a low forward drop but not better recovery. The recovery can even be more sharp. They also have some leakage.
What we need is fast and soft recovery for little EMF.
I would prefer soft recovery over low drop, both would be nice, but loosing 1V is not very important to me.
Old 17th January 2012, 12:19 AM   #4462
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Here is my motor noise snubber.
This looks like my yesterday dinner
I bet the taste, eehhhmmm the sound is terrific
Audiofanatic
Be nice to animals.
Old 17th January 2012, 12:27 AM   #4463
MiiB is offline MiiB  Denmark
http://www.vishay.com/docs/94060/hfa16tb1.pdf
could be a good diode..
Old 17th January 2012, 12:52 AM   #4464
nicoch58 is offline nicoch58  Europe
good! not the price 9.37€
Old 17th January 2012, 02:04 AM   #4465
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Mpp
I use those in my tube amp for its B+. They are good parts.
Old 17th January 2012, 03:16 AM   #4466
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Funny, i use them too. Also the bigger 25A version.
Here is my Bakers 5.
UF4004 is the second one from the left.
Old 17th January 2012, 03:24 AM   #4467
Audiofanatic, this is actually a full functioning MC phono stage with an inductive input.
I build that for ETF2011.
It makes the 75usec with the inductance of the cartridge plus the input inductor. The inductor has 4 tabs for different cartridges. By coincidence i found out that i could hear the motor of my turntable in the speakers when i put the input coils near my turntable. I left in the RIIA instead of a linear amp because then i get gain in the bass.
When i use it for listening i put the coil in a Mumetall container.
Old 17th January 2012, 04:56 AM   #4468
Maybe we should use point contact diodes.
They drop only 0.2V and have superb high frequency characteristics. Junction diodes : SOLID-STATE DEVICE THEORY
Old 17th January 2012, 05:23 AM   #4469
GaryB is offline GaryB  United States
Mpp
I've had good success with Fairchild Stealth soft recovery diodes. For example, these have worked very well for me in various preamps that I've built.
http://www.fairchildsemi.com/ds/IS/ISL9R460PF2.pdf
And they're not too expensive - $0.75 each at Mouser.
If low drop out voltage is needed then one doesn't need to go to a point contact diode. One can get schottky diodes with very low voltage drop - it's basically the same mechanism as a point contact, with the turn on voltage set by the work function of the metal contact vs. silicon. These diodes have Vf ~ 0.3v which isn't too bad.
http://www.diodes.com/datasheets/ds30492.pdf
---Gary
Old 17th January 2012, 08:41 AM   #4470
hesener is offline hesener  Germany
Mpp
And high temperature use.
are you planning to use your power supply at 300°C? ;-)
MppHide this!Advertise here!
