MPP
MPP
Old 14th January 2012, 12:15 AM   #4361
Bksabath is offline Bksabath  United Kingdom
Banned
First lay out on 160 X 100 mm
Looks like single layers and no jumpers is possible.
Snags list
Rather long track return from LEDS
Pain in the but to tighten the power devices to the sinks.
Still loads of work to do but I would like to line up the power "transistors"
on the edge of the board.
I have a Pesante Dissipante which has already sinks fitted..
I can make boards much more simmetric than on firs lay out
Or maybe 2 boards for positive and negative rail.
I have used standard .6 W resistor size this will need changing maybe?
Old 14th January 2012, 12:23 AM   #4362
Banned
On Trafos
I would like very much to use separate enclosure.
On atachments sorry for poor quality (limited file size)
I can email if needed...
PCB program I am using is Easy PC
Do not spend money on it as RS Components has a free download of same program which also has much beter library set
Old 14th January 2012, 04:47 AM   #4363
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
You are working on the regulators that are already on Heseners board. Fine, we can use that for other projects. What we need is the components that go in the external box, Frans post 4336. That is what i call the pre regulator. For double mono we need two.
Old 14th January 2012, 08:43 AM   #4364
loek is offline loek  Netherlands
Default Coils
Frans has 100uH instead of 100mH in his schematic.
Regards, Loek
Old 14th January 2012, 09:05 AM   #4365
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Regards, Loek
Ahhhh that is a mistake, there is also a link to the actual component in the post and the schema, these are correct.
The correct value is 100mH.
Sorry for that.
Frans.
Old 14th January 2012, 09:13 AM   #4366
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Hi Frans,
why do you use two bridges? Since we use a shunt reg, both polarities would sink the same current, so no imbalance can occur.
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 14th January 2012, 10:04 AM   #4367
MRupp is offline MRupp  Germany
MRupp's Avatar
Hello Frans,
Is there a reference to the original article with the transformer plus common mode choke before the rectifiers, on the soundhost pages I only see general info on transformers.
Btw, in a bridge you have always 2 diodes in series, and also the snubbers if you place them across each diode. You can therefore replace four RC snubbers with a single one. Also, the snubber resistor value needs to be in the right ballpark to be effective. I would refer to the classic Hagermann article with formulas but I have no idea how the extra choke interferes with the transformer
Martin Rupp
Old 14th January 2012, 10:59 AM   #4368
FdW's Avatar
MPP
Originally Posted by Onvinyl View Post
Hi Frans,
Rüdiger
It's just the way I use to do it. Normally I will use bridges like these:
3N255 Fairchild Semiconductor Bridge Rectifiers
They are 30 cents each and are (unavoidable) bridges and they sit here in a little box, ready to use.
Hi Frans,
Designing a 'high end' and high quality power supply should not compromise anything, having separate bridges for both supplies is a sign of quality that should not be removed (just to spare a few euro's).
Hi Frans,
Bottom line, this is the way that I would do it
Frans.
Old 14th January 2012, 11:03 AM   #4369
FdW's Avatar
MPP
Originally Posted by MRupp View Post
Hello Frans,
No there is not, this is what Joachim and I (and others) do think will be a good, solid and high quality 'raw' power supply (pre regulator). The reference is intended to give some information (for those that need it) about wiring (and other) issues.
Old 14th January 2012, 11:03 AM   #4370
Onvinyl's Avatar
Hi Frans,
it's ok for me when you say it's your way, but it ain't, when you say it's the best, which it isn't (has been a topic at diyaudio now and then).
Rüdiger
MPPHide this!Advertise here!
