Mpp
Mpp
Old 13th January 2012, 07:55 PM   #4341
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That depends on the circumstances. Sometimes a filter makes some sounds softer so you think you lost volume. When a dynamic passage comes around the impression can be different. Usually i find that a lower distortion system sounds more quiet but also has better dynamic range. Sometimes it helps to advance the volume a bit. A low distortion system can be listened to with higher volume without discomfort.
Old 13th January 2012, 07:56 PM   #4342
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Mpp
Originally Posted by nicoch58 View Post
eheh Ricardo I see fancy blu screw ...titanium?
edit PS
plus Jupiter caps..how sound?
Unobtainium blue finger nails polish (fixes screws so they do not fly with transient behaviour It is also a safe procedure... Once I lent this build to a local hifi club and found that it had been dismantled, so it tells me if anyone did try to remove them during a listening session)
No Jupiter caps... Jensen four poles. In this SE build with low PSRR, even the smoothing caps are important for high freq detail.
RC
Old 13th January 2012, 08:02 PM   #4343
nhinstruments
RCruz's Avatar
Mpp
Well I listened to my builds with the mensioned mains filters and also with some goldenote (super filters) and I also have a monster cable filter like those and always find that they kill the "magic".
I must refer that I live in a "factory free area", so the mains are quite stable and noise free here.
RC
Old 13th January 2012, 08:06 PM   #4344
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Mpp
Blue nail polish for Ergal looks and anti tampering clues then. We just have to make sure nobody we know watches, when we carefully pick nail polish arguing about color with the girl in the local cosmetics shop though.
Old 13th January 2012, 09:43 PM   #4345
FdW is online now FdW  Netherlands
FdW's Avatar
Mpp
Is it this one ? JAZZ Nagellack - pandemonium - Zalando.de
Old 13th January 2012, 09:51 PM   #4346
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Silly question Frans.
Would anyone expect anything from a Phonstage
whithout "Pandemonium" ?
preregulatorpeterE-MAIL
Old 13th January 2012, 09:52 PM   #4347
Salas's Avatar
Mpp
Niiice!
Old 13th January 2012, 09:58 PM   #4348
Benedetto's Avatar
See ?
Old 13th January 2012, 09:59 PM   #4349
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by FdW View Post
Happy new year to you and everyone around you
And I do have a New Year’s present.
Extensive research in the new year has led to the discovery of an small but useful improvement to the power supply.
The line regulation under extreme load can be improved significantly by replacing the 2.2K resistor with a 2mA current source. Line voltage ‘swing’ under extreme load (50mA AC on top of 50mA DC) goes down from 346uV (already very low) to 27uV (and that is extreme low).
The current source can be created by replacing the resistor with a J310 fet that has an 1.5K gate-source resistor connected (see detail schema).
P.s. I already informed Hesener and he will make the change.
P.s. Joachim this solves the ‘not so low floor’ problem in the previous FFT, the FFT floor is now about 33dB lowered. See: 3988.
Is this the Last circuit for the pre regulator ?
I have also seen a version including negative railand string of 12 LED.
Same components shown differ from the 2 SCH as in this post the outline of LT1028 is shown.
I am going to start the one with both rails then modify from there
Old 13th January 2012, 10:01 PM   #4350
nhinstruments
RCruz's Avatar
Mpp
Here you have
Frank Zappa-Stinkfoot live 1974 - YouTube
RC
MppHide this!Advertise here!
