Mpp
Mpp
Old 12th January 2012, 12:21 AM   #4271
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
You can put coils in the gates and then 8 is the limit. I even managed a prototype with 13 Fets at the input. Sometimes it likes to work, sometimes not.
Ricardo, the "Loesch" circuit has the Fet at the bottom in the cathode chain of the ( top ) tube. That way the noise of the tube is not correlated with the noise in the Fet, just as in the Simplistic Salas. The top BC550 has 140 Ohm Rbe`, still it does not contribute much to the total noise of the circuit. The BC550 is common base so it only amplifies the voltage and not the current.
Old 12th January 2012, 12:31 AM   #4272
Bksabath is offline Bksabath  United Kingdom
Banned
Joachim
Tanks for that SCH
I use a similar MC front end on my Salas Simplistic.
Just a couple more stages with J fets not Valves.
Suply of inversed polarity as I use 4 2SK170.
There are a couple of things In your drawing that I will try up
I have 33 Homs as source resistors and ommited the 25000U capacitor.
Old 12th January 2012, 04:34 AM   #4273
Bksabath, the Simplistic is not a folded cascode but a series cascode so schematic 4268 is not directly comparable. The Simplistic could be transferred into a folded cascode though.
33 Ohm as source resistor in an MC stage is rather high.
Old 12th January 2012, 07:21 AM   #4274
gk7 is offline gk7
Borbely did a cascoded FET/Tube phono input in 1997.
Old 12th January 2012, 07:29 AM   #4275
reinhard is offline reinhard
And Sonic Frontiers, and Manley, and Melos, and many Others
Reinhard
Old 12th January 2012, 07:33 AM   #4276
The question is who did it first ?
Old 12th January 2012, 08:59 AM   #4277
gk7 is offline gk7
Probably HP or Tektronix (although not for a phono stage of course).
Old 12th January 2012, 11:06 AM   #4278
Just for completeness. This is a clone of the Arthur Loesch preamp.
Old 12th January 2012, 11:29 AM   #4279
as_audio is offline as_audio
Default Earliest hybrid cascode?
In
http://www.audiodesignguide.com/ba/prepsc.jpg
you can find downpage "Preampl. zero feedback by Bartolomeo Aloia" .
The diagram http://www.audiodesignguide.com/ba/prells.jpg
however is not easy to read. It is pre 1988.
Old 12th January 2012, 12:06 PM   #4280
Yes, Bartolomeo Aloia did BJT-tube cascodes and also Fet-tube cacodes, mostly with 3 elements in series like in your link. He called that Totem-Pole.
MppHide this!Advertise here!
