MPP
MPP
Old 30th December 2011, 02:35 PM   #3981
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, Martina was the beta tester on many incarnations. Martina has very good technical knowledge of mechanical things. She has repaired my coffee machine, my telephone, debugged my computer, repaired my car and other things. It is only when it comes to electronics she can not follow each and every little detail but i think that is a blessing because she it not very biased in terms of topology. When it does not sound right to her she does not care about the underlying technology ( she cares actually, but i hope you understand what i mean). Martina has also a different way to listen to audio. For example Martina loves classical music and especially older recordings that are sometimes hard to reproduce. Instead of judging the technical excellence she compares the sound of reproduction to the sound of real life music.
She is an expert on the human voice and there was in the beginning where i failed. At first i simply restored to the old garbage in garbage out argument but then we found that the sound of voices can be improved by improving the phono stages. And so it goes..
Old 30th December 2011, 02:51 PM   #3982
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
MPP
The BBC heritage of getting the voice right first had serious basis.
Old 30th December 2011, 03:14 PM   #3983
Sure, i worked at Essex University in the early 90th so i got a fair dose of that good poison. Actually the Pro AC Tablette was the speaker that impressed me so much that i founded Audio Physic. I fantasized when something so small can make so much music there must be a customer potential, and i was right.
Old 30th December 2011, 04:26 PM   #3984
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default Martina Danke !
Hi Martina & Joachim,
Now I understand why Joachim is so good in making music sound at it's best through his equipments; he fine tunes his products via Martina's ears
Well I actually do the same thing here, I ask my sweet partner to judge my work and if it's OK she will smile and close her eyes and keep on listening.
Danke Martina, danke Joachim and thanks to all of you who helped to make this thread a big success ! Happy new year to you all.
atb,
José
Audiofanatic
Be nice to animals.
Old 30th December 2011, 05:00 PM   #3985
No cheaten, no eaten
Comander Crichton, Farscape
Old 30th December 2011, 05:02 PM   #3986
Default Mr G.
Audiofanatic
Be nice to animals.
Old 30th December 2011, 08:49 PM   #3987
hesener is offline hesener  Germany
MPP
sorry I was offline a few days.... layout is proceeding, on the ground planes in the amplifier section now...
happy new year to everybody!
(repeating the nice and very true comments about this thread seem boring at this point, but I fully second...)
Old 30th December 2011, 08:53 PM   #3988
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Default Needs some explanation, I think.
Someone, in a private mail, called the Sziklai pair and capacitor in front of the LM317 current source an capacitor multiplier , and that it is not!
Actually the arrangement is a constant voltage source that supplies the current source, and the reference voltage for this voltage source is the output voltage of the shunt regulator.
This way the voltage supplied to the current source is as stable (about) as the voltage supplied by the shunt, and that voltage is very stable.
In effect this arrangement ‘degrades’ the LM317 to be a ‘mime’ of a resistor, the amount of work it has to do is minimal and the quality of the component is of minimal influence on the quality of the regulator.
Attached an comparison with a ‘standard’ shunt regulator and an enhanced version of the standard shunt regulator.
Anyway I hope you like it.
File Type: jpg VReg compared with standaard shunt.JPG (259.7 KB, 262 views)
Old 30th December 2011, 09:17 PM   #3989
Hello Hesener. Welcome back. I know you are busy.
Frans, thanks for clarifying this.
I asume that the red trace is yours or is it the green trace that has somewhat better hum rejection ?
Old 30th December 2011, 09:23 PM   #3990
The standard solution with TL431 can be somewhat improved with 220uF over R3.
MPPHide this!Advertise here!
