Mpp
Mpp
Old 25th December 2011, 10:59 PM   #3861
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Originally Posted by Holger Barske View Post
Be assured: No problems with quality. And of course no problems with soldering, as boards are tinned (as is every professional made pcb unlesse you don't want it).
I second that .
preregulatorpeterE-MAIL
Old 26th December 2011, 12:20 AM   #3862
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Ok, why not try it. Although this design needs a lot of ( mostly inexpensive ) parts we where trying from the beginning to make it economical. Lets use that supplier from China.
Red boards with tinned copper.
Old 26th December 2011, 02:39 AM   #3863
There is another effect in bipolar transistors i did not mention : the Kirk effect.
Here is some information:
Bipolar Junction Transistors
Old 26th December 2011, 03:17 AM   #3864
Ricardo, for this kind of project i usually use Wima FKP1 2,5%. They are PP film and foil.
Very good and inexpensive. When you parallel them you get even closer tolerance because they even out (Douglas Self). For example you can use 4 x 10nF plus 470pF plus 330pF.
You can also use 6,8nF everywhere : 2 x 6,8nF = 13,6nF and 6 x 6,8nF = 40,8nF.
Old 26th December 2011, 03:28 AM   #3865
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default Merry Christmas my friend
Hi Joachim,
Merry Christmas to you and your family
BTW I also use the FKP1 and the Siemens caps I like them.
atb,
JosÚ
Audiofanatic
Be nice to animals.
Old 26th December 2011, 03:54 AM   #3866
We both like the same. It┤s a miracle.
Old 26th December 2011, 03:55 AM   #3867
Hesener, please make space for the Wima 6,8nF FKP1. I think that is a good solution.
Old 26th December 2011, 04:04 AM   #3868
Default Miracle
Hi Joachim,
Yes we like the same things it seems
We both are awake also and we both like to make things better.
The biggest difference between us is that you are blond and I have black hair
Beautiful and crazy at the same time isn't it?
Thanks for all your support in this thread, it's just great !
atb,
JosÚ
Audiofanatic
Be nice to animals.
Old 26th December 2011, 08:56 AM   #3869
hesener is offline hesener  Germany
Mpp
ok no problem
Old 26th December 2011, 08:59 AM   #3870
Mpp
Originally Posted by RCruz View Post
Regarding the Riaa caps, I see 2 x 20.4nF and 2 x 6.8nF
The 6.8 value (6800pf) is easy to find and my 1st choice would be Relcaps RTE - Polystyrene Film & Tin Foil, but 20.4 .... Can not find it anywhere.
HiRicardo,
my first approach was to put place for two caps so people could select and put whatever they want in parallel.... anyway, the choice right now is to put Wima FKP1 so I will change the footprint to that, should fit most others anyway.
what is the size and grid spacing of your caps, just curious?
MppHide this!Advertise here!
Copyright ©1999-2017 diyAudio
