Mpp
Mpp
Old 17th December 2011, 09:18 PM   #3721
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
Well,
u are.
Captain.
preregulatorpeterE-MAIL
Old 17th December 2011, 09:35 PM   #3722
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Talking Captain G
Originally Posted by Benedetto View Post
Well,
u are.
Captain.
I second that !
Audiofanatic
Be nice to animals.
Old 17th December 2011, 09:48 PM   #3723
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Old 18th December 2011, 05:41 PM   #3724
If this ones work it would be good. They are inexpensive :ZD 3,9 - Zener-Diode 1,3W 3,9V - Z-Dioden, 1,3W bei reichelt elektronik
Old 18th December 2011, 07:03 PM   #3725
hesener is offline hesener  Germany
Mpp
Hi all,
layout work will start tomorrow, I am going with the schematic of post 3688 at this point - should be good enough for starting. I will be making place for 1/2W resistors, big input caps and some larger resistors where indicated. Plus, of course, the shunt regs.
Speaking of which - Frans could you give us an estimate of the power dissipation of the regulators, for choosing an appropriate heatsink?
Old 18th December 2011, 07:32 PM   #3726
FdW is offline FdW  Netherlands
FdW's Avatar
Mpp
Originally Posted by hesener View Post
Hi all,
These are the numbers:
D45H11/D44H11 1.7W
LM317/LM337 0.7W
IRF610/IRF9610 1.1W Under normal (105mA) load condition
IRF610/IRF9610 3.6W When preamp disconnected
This is for a 24Vac transformer, for every Vac rise on the transformer the power consumption of D45H11/D44H11 will rise with about 250mW.
Old 18th December 2011, 07:39 PM   #3727
Thanks Hesener and FdW, good start.
Old 18th December 2011, 07:46 PM   #3728
Mpp
That was quick Frans, thanks a lot!! These numbers are not very high but high enough in my opinion to merit a good heatsink.
Three options:
- locating the power components on the edge, so they can be attached to an external heatsink
- (several smaller) heatsinks that can be soldered onto the PCB
- one larger heatsinks (e.g. 80mm) that goes across the PCB and all power components are attached (requires isolation pads)
opinions?
Old 18th December 2011, 08:24 PM   #3729
FdW's Avatar
Mpp
Three options:
opinions?
Shared heat sinks is best, option one or three. Option two is problematic due to the different wattages being dissipated, needing different sizes.
Option 1 or 3 needing heat sinking for about 6Watts.
This can be done on the PCB (6Watt), so I would go for option 3.
Under normal conditions (preamp connected) 3.5W is being dissipated. I would go for +20 degC (above environment) and that would need a 5 or 6 degC/Watt heat sink. That sets an (acceptable) temperature increment of about +30 degC when the preamp is not connected.
Old 18th December 2011, 08:26 PM   #3730
I agree. That is more simple.
MppHide this!Advertise here!
