Study the spec sheet and look where the main cap has it´s minimum impedance and blend in the bypass where the main cap starts to be inductive.
excellent advice, applicable also to bypassing in power supplies
You have to find out yourself. Sorry, no spoon feeding. You find it on this thread somewhere. It is not a secret, just a lot of listening and measurements. One Tip : the rule to bypass the main cap with a cap that is 1/10nth the value does not work. The bypass cap is much smaller.
For speakers it it different because of the high currents that flow and the immense shaking. What matters most here is to suppress mechanical resonances.
A densely wound MKT can sound better then a teflon cap with loose windings.
Dielectric absorption is a minor problem in speakers because the cap can not build up much energy. The low impedance of the speaker short circuits the cap mostly all of the time.
I agree... After numerous experiments I found that bypassing a 4u7 MKP with a 15pF SM gives the best results in some of my preamp builds.
Ricardo, this is an extreme case but i trust your listening. I usually land in the 1 - 3.3nF range so it is more like 1/100 or a bit less. This could be also system dependent. That was the reason i said " no spoon feeding ". Had i given the makes and values people may have thought that they are the holy grail preventing them to do their own experimentation.
